Go Back   Automotive Forums Car Chat > Ford > Windstar
Old 10-20-2006, 12:58 AM
MrCreosote MrCreosote is offline
2000 Windstar no 12V @ OBD II Connector Pin 16
Pin 16 is supposed to have +12v. I have nothing there even with the ignition switch turned to ignition on.
Does anyone know if there is supposed to be 12v in the connector (read some OBD II do NOT have 12v at pin 16 (or any other pin for that matter)).
If there is supposed to be, where does it come from - what fuse?
Thanks
Tom
Old 10-20-2006, 07:18 AM
busboy4 busboy4 is offline
Re: 2000 Windstar no 12V @ OBD II Connector Pin 16
Hi
Here is a link to an OBDII standard diagram. Actually looks to me to be pin 13 which is "jumped" to pin 16 on the connector, but whadda I know Anyway, should be unswitched power there someplace as the reader draws its power from the connector. Your reader should power up regardless of key position. Hope it helps.
http://www.avt-hq.com/716_s05b.pdf
another: http://www.avt-hq.com/obd_02.pdf
Old 10-20-2006, 11:13 AM
Busboy4,
Looks like the pin 16 is the 12v at the car, then the "OBD II Cable" switches the 12v from 16 to 13.
Thanks for the diagrams.
I'm almost certain I used this scanner to do my 171/174 codes so I'm figuring I have a blown fuse or something. The Owner's Manual doesn't refer to the OBD II Connector in the fuse table as far as I can tell (may have missed it - it is a big table).
I would be nice to find the connector in a factory wiring diagram.
Thanks
Tom
Old 10-20-2006, 11:18 AM
Originally Posted by MrCreosote
Busboy4,
Thanks
Tom
I'll take a look in my manuals but, it is obviously on a fuse with other non-switched items. That doesn't leave too many.
Old 10-20-2006, 11:56 AM
frostie frostie is offline
On my 99, it is the same fuse as the front 12V accessory outlets. The fuse is a 20 amp yellow fuse (IIRC).
My son blew the fuse by running an inverter off the 12V outlet, and I only found out about it when I went to clear some codes and my scanner would not connect.
Old 10-20-2006, 12:06 PM
Hi
Looking at my elec/vacuum manual. Ford calls the plug the "Data Link Connector" DLC. It shows pin 16 to be battery power, then calls 13 the "reprogramming power supply". Also, my owners manual for the OBDII scanner says that you should have power at 16. So, I guess you do have a problem. Unfortunately, I do not see where power comes from for pin 16. It simply says battery power.
I am only guessing here, but I would think pin 13 "receives" power/signal (reprogramming power) to the PCM when you push read/erase on the scanner.
Old 10-20-2006, 03:21 PM
I called Actron and they looked it up in Mitchel:
There is a purple wire that connects pin 16 to pin 13 of the main computer.
So either my computer is not producing 12v @ its pin 13 or the violet wire is broken.
I probably should cut the violet and feed the OBD connector from something like the cigarette lighter.
Old 10-20-2006, 04:29 PM
garync1 garync1 is offline
Oh be careful... Just unhook the battery to reset.. LOL
Or take to autozone to double check your OBD connection..free
Old 10-20-2006, 06:13 PM
I would disconnect the battery, but I know for sure that unsets all the readiness states. Someone posted that clearing the codes does not unset any readiness states. ... well definitely not all of them.
Old 10-21-2006, 11:57 AM
FIXED!
Found blown 20 amp FUSE #17.
Scantool works, codes cleared.
