Go Back   Automotive Forums Car Chat > Chevrolet > Blazer > Problem Diagnosis
Old 10-18-2006, 08:48 PM
DetroitMuscle's Avatar
DetroitMuscle DetroitMuscle is offline
Send a message via AIM to DetroitMuscle Send a message via Yahoo to DetroitMuscle
4.3 lacks pickup
I have a 92 T-10 2 dr 4x4, it has a 4.3 Z motor, It runs fine, a vacuum leak in the 4x4 system but thats what a twist lok cable is for. It lacks pickup, Ive done a full tune up, just had a cat back put on not to long ago, it has 147K on it.
Any info on where to look is helpful, ive also cleaned the EGR valve.
Thanks
Old 10-18-2006, 08:52 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
Re: 4.3 lacks pickup
is your ses light on? if your truck has O2 sensors, how long has it been since they have been replaced? a bad o2 can richen the engine and cause it to stumble. you may need to run a bottle of fuel injector cleaner through the tank if you have not done so in awhile.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 10-19-2006, 05:23 AM
Originally Posted by ZL1power69
is your ses light on? if your truck has O2 sensors, how long has it been since they have been replaced? a bad o2 can richen the engine and cause it to stuble. you may need to run a bottle of fuel injector cleaner through the tank if you have not done so in awhile.
Ive seafoamed it, no lights but ABS for right frnt sensor, O2 I havnt checked but its not stumbling, It drives fine, until I floor it then it takes forever to respond and when it does its very weak. The tranny is not slipping at all either, Im confused, The motor was rebuilt almost 30k ago.
Old 10-20-2006, 10:11 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Reset your timing to base zero.
Unconnect the black and tan wire under the passenger front footwell carpet going to the PCM, you will see a connector you can unattached.
Set the timing to zero.
Reconnect the wire.
Also, what did this full tuneup include?
Old 10-21-2006, 05:56 AM
Reconnect the wire.
Plugs,wires,cap,rotor,all filters, coolant change, all fluid change, wipers, basically a very expensive tune up. Now setting the timing on these pigs is identical to small block chevy timing adjusting , correct?
Old 10-21-2006, 09:31 AM
BlazerLT's Avatar
AF -Advisor
Remove the timing wire, set to zero, reconnect wire. Remove negative battery cable to clear the computer and start'r'up.
Old 10-21-2006, 10:50 AM
Will do, thanks.
Old 10-21-2006, 11:04 AM
Cloud Strife Cloud Strife is offline
Plz give an update to this thread once you complete the clearing process. I am interested in the results.
1999 Blazer 4x4 LS "Blackie"
Monroe Reflex Shocks
Moog U/L Ball Joints
K&N FIPK Gen 2 Cold Air Intake
Flo-pro Soundpro exhaust
Optima Redtop
132k miles and still rolling....
Old 10-21-2006, 11:17 AM
Im gonna try to do it today but might not happen for a few weekends yet.
Old 10-21-2006, 12:43 PM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
I agree with LT check the timing, and adjust if needed. If that doesn't work, disconnect the EGR , and plug the line, and take it for a drive, see what that does.
Old 10-25-2006, 05:38 AM
I did the EGR thing, it didnt change anything at all. the idle didnt even stumble when I pulled the line.
Old 10-25-2006, 01:14 PM
mattyspankin mattyspankin is offline
have you had the fuel pressure checked, you could have a bad pump....?
my 4.3 was lacking pickup as well changed the pump and module and it runs like a top now....not enough pressure means not enough fuel therefore engine wont run like it should
Old 10-25-2006, 01:24 PM
BlazerLT's Avatar
AF -Advisor
And what about the timing?
Old 10-25-2006, 06:10 PM
I didnt get to it that day, the new weekend isnt here yet. I doubt I can do it this weekend either.
the Fuel pressure is fine, the thing moves when you floor it in first but if you are in 3rd or OD and kickdown to 2nd(passing) it doesnt have the pick up it should, Other then that it runs just fine, a little noisy but i get between 13-19 mpg to each tank. I want to know why nothing changed when the EGR was unplugged.
Ive always ditched the smog systems first but this car needs to keep em due to its daily duty.
Old 10-25-2006, 06:25 PM
twistedtech twistedtech is offline
For starters,if the plug gap is off either way it will affect alot of different things.Wrong plugs,cheap wires or what ever will cause issues as well.The timing can handle more than a 0 base,try it 6,8 maybe even 10.As far as the in tank fuel cleaners,save your money,they only clean the pintle and the pintle alone.A real carbon clean,ie:motovac, will clean all,intake runners,valves etc etc.
If it ain't broke.......screw with it till it is.
Even at a Mensa convention,
Someone's the dumbest person in the room.
