| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
Drag Strip
Me an my friends are having a lil bet. We are all going up to the tracks here soon. We get to use any car we wont to fix up, but it has to be a 1.8 an nothin larger. I wont to no if i am able to turbo a 1.8 Eclipse? An if so would put any damage towards the motor or not. An is the 1.8 eclipse really that bad? I mean people dont like them for some reason.
Re: Drag Strip
Turboing them is possible, but in most cases impractical. The 1.8 is a SOHC which is sbustantially less efficient than a DOHC setup and the engine just plain isnt built for boost. Selling the car and buying a already turbo DSM will get way more bang for your buck. If you do a search (might even be a sticky) there is a guy that did a pretty good writeup on turboing a 4g37 so if you really want to do it you can.
Like I said, I would just start looking for a 1g turbo car. A decent running 1g AWD can be had for like $1500 and less if you are willing to do some work and FWDs are cheaper than that (get an AWD though, way cooler ). Also, Talons are generally cheaper than Eclipses and Lasers are cheaper than Talons. Good luck which ever way you go.
Re: Drag Strip
Thor's right about the impracticality and all but I think you missed the point. The car has to be a 1.8. In that sense, if your going to do the ecplise as your drag car I think you would have much more to gain from weight reduction then adding horsepower because it would just be so hard. Obviously anything is doable and heck I kinda want you to so I can see what numbers you put down.
So in conclusion I say get that 1.8 rip it apart and then see what times it can do then gauge how fast your friends car is going and factor in how much you really want to spend and then and only then think about turboing it. Good luck man.
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM. 18 Inch chrome rims In closet AEM Fuel Rail, SS Lines, 1997 TSI AWD Diamonds Are 4Ever 12.7 @ 107 http://i83.photobucket.com/albums/j2...y/DSC00461.jpg |
Re: Drag Strip
If you can't go over 1.8 best bet is to build a honda motor. You can make a good low 13 sec car for pretty cheap and it'll be a 1.8
1991 GSX 2.3 Stroker |
Re: Drag Strip
Ahhhh, I missed that it has to be a 1.8. Well in that case, get a Honda. *gasp* Yes, I would definately get a Honda for this one. I just plain dont have any faith in that 1.8 SOHC. Is there any money or time constraints for this bet? Heres what I would do:
Get yourself a CRX, they can get pretty cheap. Or if you can get a chassis with no engine in your area, that would be even better. I would imagine a CRX shell could be had for quite cheap, probably $300-$600. I would then get a B18 engine (came in Integras, maybe something else). If you can find a B16 head, snag that up too. B18 bottom end + B16 head = LS Vtec, a Honda combo I can respect. Couple that with the close ratio tranny out of a vtec Del Sol (may be in other cars too, I can find out for you if you need me to)and you will be set as hell. I woud strip and gut the hell out of that CRX, IIRC when stripped and gutted, they can be like 1800 lbs without the driver. Then you can go one of two ways with that LS Vtec, either NT or boosted. If you go NT, I would get some good cams, Eagle rods, higher compression Wiseco pistons (I hear 11.5:1 is the highest you can go on pump, you could get 12.5:1 and run race gas if you wanted). If you decide to go boosted you will be able to make more power, I would suggest that route. I would rebuild the engine with some good turbo cams and probably 8.5:1 - 8.8:1 compression ratio pistons, and a big 16g or a Evo III 16g. Remember, 350 hp in that little CRX is going to do a lot more than it would in a DSM. Oh, dont forget Hondata, its like the DSMlink of the Honda world. Then all you should need is an LSD and some wide/sticky tires up front and bam, you will be fast as hell. If you can get that FWD to hook up on the launch, 350 hp in a 2000lb car should get you into the 11's pretty easy I think. Hope some of that helps.... |
Re: Drag Strip
Time.....Yes there is a time limt but i allready pick the eclipse so i am stuck on that one.
Re: Drag Strip
I have a 1.8 Eclipse......SLOW!!!
All I can say it floor that bitch and hope ya win. go find ya a honda hatch back and tweak it out. Good luck |
Re: Drag Strip
seen it done... and got my ass handed to by one... thats one fast set up right there!
Re: Drag Strip
yep im building a fully built and stroked ls vtec for my buddy ron at work. he plans to also turbo it. its a older integra like a 90 or 91. he got no interior but one seat, skunk 2 coilovers and every adjustable suspension part you can buy and crazy wide slicks.
hes going to spank me like a bitch, and it sucks cause i built the motor
1992 eagle talon tsi awd xtd stage 3 six puck/apexi 3' downpipe and exhaust/ngk plugs/taylor thunderbolt wires/manual boost controller set at 20psi/walbro 255 with rewire/autometer boost gauge/turbo xs rfl blow off valve/arp headstuds/ to4b vtrim turbo/dnp tubular manifold with o2 housing and tial 38mm wastegate/eagle rods/ross pistons/acl bearings/arp rod bolts/arp main studs/aeromotive fuel pressure regulator and all stainless lines/aem fuel rail/slowboy street front mount kit |
Re: Drag Strip
Yup get a crx get rid of the 1.8 eclipse lol
Current Cars 2006 Eclipse GT 6 speed MT (V6 3.8), mods so far- S Tech Springs, after market 18's, 2012 headlight Conversion, Greddy cat back exhaust, CAI, RRE Headers, Polyurethane Motor Mounts, NX Nitrous kit at 100 shot for now, RPM Window Switch, Triple Pod. 2003 Grand AM GT - official beater car for the winter lol ---------------------------------------------------- 95 TSI AWD [email protected] (T-25) Now fully Modded engine with 3,560 miles on it.SOLD |
Re: Drag Strip
I have a 1.8 and it doesnt like to move. I think the volumetric efficancy is only around 75% or so, so its wasting alot of power. Stip weight off the sucker, as much as you can. Ive noticed a differance with and without passengers.
Id also do in a quick portmatch job, some headwork, and alot of praying. Im going to build up my 1.8, not for speed, but just because I like how it sips gas and because Its my first ground up motor, no biggie if it blows up. +1 on just getting a Honda.
1990 Eclipse, 1.8 5 Speed. Pioneer sound sytem, shifter mod. ![]() 1986 Ford F-150, Glasspack, some emissions stuff removed, cleanest interior in the land. Pioneer sound system.
Re: Drag Strip
Me and my friend built his LS/Vtec motor, Took us about 3k including the cost of the car. And we put Type-R pistons and cams in there. After that we threw a 75 shot on there and wala a nice low 13 high 12 sec car.
We just put it in a 91 hatch. Things fast as crap.
Re: Drag Strip
Done right, Hondas are a force to be reckoned with. My buddy is going to be building a CRVtec (2.0 block B16 head) for his Del Sol. That thing is already pretty quick, I cant imagine it with 25% more displacement, 11.5:1 pistons, some nitrous, and some wicked cams. Also, my buddy has a stripped and gutted older hatch slammed to the ground and a D16 (SOHC Vtec). Even though its not much and all it has for performance parts in I/H/E, he still manages IIRC like 13.6-13.9's in the 1/4. Have you figured out what you are going to do with that mitsu 1.8? Going to run a turbo setup in there or ditch it for a Honda 1.8? |
Re: Drag Strip
LS v-tec swaps are Not relieable and the motor does not last long. Unless you put some serious money into the motor. I do alotta honda swaps in my area and there all BS. No matter what you do to it...its still gonna be slow unless you got 15 grand in your pocket
Re: Drag Strip
While I tend to agree that they are not reliable. As long as you don't beat the hell out of them they will last a while. My buddies motor has 30k on it and is still going strong.
