ck trans light and cruise engage light
2000 passport automatic 140,000 miles
3.6l after warm when shifting and/or when coming to stops the ck trans light and cruise engaged light come on will go out once trans shifts hard into next gear. if they come on when coming to stops the vehicle stalls help me thanks |
Re: ck trans light and cruise engage light
what is the history on the fluid changes on the tranny?
Is there enough fluid in the tranny? Your dieing at a stop could be a bunch of thing: 1. Bad intake manifold gasket (very common) 2. Dirty EGR system (very common) 3. Old plugged fuel filter 4. dirty MAF sensor.
-Ryan Isuzu Moderator Car Show Tips Operations manager with a results-driven passion for process improvement FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd |
trans fluid in good condition
intake gskt just replaced (problem present prior to replacement) egr replaced a month ago no codes in computer |
Was the EGR tube cleaned too (see the faq's)?
History on the fuel filter? When you pull the auto trans select through the gears (slowly) do the numbers on the dash match up to the ones onthe selector? Are you the orginal ower? Do you know the flush history of the tranny? If so what mileage was it done at? "ck trans light and cruise engaged light" I think that means your battery or alt is on the way out. The tranny will do funny things if it is getting too many volts or too few. Have the battery and alt load tested (many have done this to alts and it tests ok, and still have issues, then the replace it and it goes away).
//bc
1992 trooper 3.2L v6 sohc automatic...as is i love a good intermittent electrical challenge. . .especially when it's someone else's. |
