Go Back   Automotive Forums Car Chat > Chevrolet > Blazer > Problem Diagnosis
Old 10-08-2006, 08:33 PM
hcary hcary is offline
Cool Transmission Fluid Overflowing From Tube
On my 01' jimmy, I seem to have an intermittent transmission fluid overflow problem coming out of an overflow tube above the gear-shift cable.
I've noticed driveway drip spots on 3 occasions in the last week or so.
I took these pictures to show you what I'm talking about. Any ideas?
Old 10-10-2006, 01:49 PM
Re: Transmission Fluid Overflowing From Tube
::bump::
Old 10-10-2006, 02:39 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Originally Posted by hcary
::bump::
Fluid level and mileage and transmission and engine.
What is the service history on transmission?
How much is it leaking?
Is transmission heating up or slipping or shifting rough?
What transmission fluid are you using in it?
Any towing in overdrive?
MT
MT
Old 10-13-2006, 05:10 PM
It's a 2001 with 106k miles. Service history is a flush and filter service at 56k miles. No rough shifting, but I think there is a very random slip. A couple times a month while cruising on the highway, I'll feel a slight jolt, but the engine RPMs don't change. The dealer said everything checked out.
The overflow is more like drops. I once had a puddle about 6 inches wide, but normally just an inch or so.
I checked the levels today and they were fine, though I noticed some bubbles in the fluid on the stick...
Old 10-13-2006, 05:50 PM
MT-2500's Avatar
AF - Advisor
Silppage can cause overheating.
The most likley cause of fluid coming out the vent.
You may need to check fluid and filter again and see if anything is in the bottom of pan.
A good repair shop can run a transmission scanner check on it and check for slippage and overheating and other problems.
Good Luck
MT
MT
