Go Back   Automotive Forums .com Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 10-03-2006, 01:09 PM   #1
J.S.
Problem with Door Locks-Olds Cutlass
I'm putting a 92 Olds Cutlass back together and after dropping a motor I am stuck at the door locks. Using the driver side button with the doors locked it will raise the driver side lock, not the passengers. The passengers won't do anything. When the doors are unlocked neither switch with lock the doors. So far I have checked both motors and both will unlock their doors but not each others. The fuse is good. Someone told me that the locks are controlled by some switch located behind the trim were the asshtrays in the backseat are. Any help will be appreciated. T.I.V.
J.S. is offline   Reply With Quote
Old 10-04-2006, 09:50 PM   #2
xeroinfinity
out saving the world
xeroinfinity's Avatar
Re: Problem with Door Locks
Did you check for any relays for the lock-unlock?
Also could be a fuse , not sure where they are tho.
1999 Grand Am SS 3.4 OHV
xeroinfinity is offline   Reply With Quote
Old 10-05-2006, 11:54 AM   #3
J.S.
yeah checked them both.. I recently got some relays from the srap yard so that may be a problem.. im going to go get some more. And if anyone know a good electronics shop to bring the car to in the chicago area, let me know. What relays are the ones for the locks I've just been replacing random ones. and thanks for the response
Old 10-05-2006, 01:11 PM   #4
xeroinfinity
I wouldnt trust relays from the junk yard
They tend to rust or corrode and not work right.
I'm not exactly sure where they are,
tho the panel that covers the fuse box should say whats where.
Old 10-05-2006, 02:11 PM   #5
J.S.
yeah. was goin the cheap route.. but I just left a body shop and he told me that its probably the acuators. I forgot to mention that I took the panels off and was able to see that the actuators will work unlocking the doors. but they don't move at all when trying to lock the doors. The passenger side won't unlock itself, but it will unlock the drivers side slowly. The guy said that the actuators are broken. Also the door for the passenger side gets stuck when trying to open them from the outside. lIke it doesnt' open freely. gotta keep trying to reopen it for it to open once. My cousin said that that could stop the locks from working and to try some wd-40. the body shop wants $110 without parts but I may not need actuators if its just the door lock being jammed and me needing a new handle and lock. What do you think?
Old 10-05-2006, 03:06 PM   #6
xeroinfinity
If they unlock then the acuator is working.
Thieris a 2 relays 1 lock 1 unlock, check that first.
Try and spray the latch on the door and the actuators actuator.
If you use Wd40, try not to get it on any connectors or the wires in general, it tends to dry out wire jackets and they crack.
If sprayed on electtrical connectors it can short out and catch fire.
On the door hard to open,
I'd oil the latch and see if that helps first.
If the door is not saging at the hinge,
you can adjust the latch on the door.
