Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 09-23-2006, 09:32 AM
evt4 evt4 is offline
Question 1998 Neon Rad Fan not coming on
I have a 1998 neon, Single OHC, Automatic, with the radiator fan not coming on. The check engine light came on and it read that the relay was bad, I replaced the realy and temp sensor, fan is still not working. I then replaced the computer with one from a used auto parts junkyard and the fan is still not coming on. If I power the fan directly it works.
Any thoughts and help is appreciated.
Thanks!
Old 09-23-2006, 10:23 PM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: 1998 Neon Rad Fan not coming on
Did you check the fuse also?
2003 Dodge SRT-4
Old 09-24-2006, 06:59 PM
Checked 30 amp fuse in engine compartment it's fine, are there others? If so where?
Thanks for the help
Old 09-25-2006, 07:45 AM
Which relay did you replace and where was it located?
2003 Dodge SRT-4
Old 09-26-2006, 07:26 PM
I replaced the solid state relay under the battery and the fuse I checked is in the relay compartment. Am I missing a fuse?
Old 09-26-2006, 08:36 PM
You got all of them. Check the wiring now...you may have an expose wire shorting something out.
2003 Dodge SRT-4
Old 09-27-2006, 06:55 AM
That's going to be a long job but I will do that this weekend thanks for the help I'll post what happens. Thanks again!
Old 10-04-2006, 06:31 PM
Kobaltic Kobaltic is offline
I had the same problem turns out it was a bad ground wire. It is located all the way up on the drivers side corner located right above the compter. There should be 4 wires going to 2 spade connectors. One wire is your fans, one is wipers, one is AC and I forget what the other is. Hope this may help.
