Old 09-15-2006, 11:43 PM   #1
scottsee
Send a message via AIM to scottsee
Spending $150... But on what?
Evo3 exhaust manifold to replace my ported 2g manifold?
Evo3 o2 housing to repace my ported o2 housing?
Used MAFT v2.01 with 3in MAF to vent my BOV?
Apexi Turbo Timer for new Evo316g?
Lowering Springs to drop the hotness?
Real J-pipe to eliminate my hacked POS monstrosity of one?
Macv viscous coupler eliminator so I can run my AWD on a 2wd Dyno?
I'm leaning twords the V-coupler Elim.
DSM geek
scottsee is offline   Reply With Quote
Old 09-15-2006, 11:48 PM   #2
Thor06
Jizzed In My Pants
Thor06's Avatar
Re: Spending $150... But on what?
Ooh, $150 for a MAFT? Shit... how could you pass that up? Personally, I think that going to an Evo III manifold/o2 sensor housing when you already have ported 2g ones would be a waste of time.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Thor06 is offline   Reply With Quote
Old 09-16-2006, 12:06 AM   #3
scottsee
MAFT would only be for my BOV. I have dsmlink..
Turbo timer would be kinda nice too on a new turbo
Going to a Dyno 3 blocks from my apartment would be Awsome, sence the nearest AWD is 600+ miles away!
DSM geek
Old 09-16-2006, 12:15 AM   #4
crunchymilk55
crunchymilk55's Avatar
Send a message via AIM to crunchymilk55
dont need a turbo timer, the evo3 is water cooled. Just don't turn it off right after it's at full boost.
evo3 housing or manifold gets my vote. Huge improvement in airflow potential.
now - 2000 civic
soon - 2002 is300
crunchymilk55 is offline   Reply With Quote
Old 09-16-2006, 12:17 AM   #5
Thor06
Jizzed In My Pants
Thor06's Avatar
That is true... judgement call I guess. If you would have asked a bit earlier, I have a turbo timer I dont plan on using, I woulda cut you a deal for it. Though nice, I think they are kinda a hassle. I would rather just chill out in the car for a few minutes and let er cool off. I personally would way rather have a loud BOV than the ability to dyno... arent the MAFT setups way more accurate than the stock DSM MAF's?
Old 09-16-2006, 01:26 AM   #6
scottsee
no, they are less acurate
DSM geek
Old 09-16-2006, 01:32 AM   #7
crunchymilk55
in fact they're a PITA, even with DSMLink.
That is unless you just buy it to vent and leave it alone.
now - 2000 civic
soon - 2002 is300
Old 09-16-2006, 06:17 AM   #8
Eclipse4ever
Eclipse4ever's Avatar
Hey Thor, what kind of a turbo timer do you have ? I am looking for one. Yesterday I saw a 95GSX that was being parted out and I bought a ISC for $5 , it had a turbo timer but I am clueless of how to take it off.
1997 Eclipse GSX
Eclipse4ever is offline   Reply With Quote
Old 09-16-2006, 01:06 PM   #9
Thor06
Jizzed In My Pants
Thor06's Avatar
Mine is one of the HKS ones. IIRC HKS has two models, one fancier one and one not so fancy. I think this is the fancier one. I dont know though. I am with you on that, I dont know how to get it off. Havent tried either, though it might be easy. I would absolutely sell it (there is going to be one hard core fuckin F/S thread in like the middle of May) but its at a friends house like 4 hours north of here.
Old 09-16-2006, 10:43 PM   #10
E-Klips
Banned
GM Maf allows you to flow more air and they are a lot less restricting. Gets a lot of shit out from in front of the turbo. Technically they are "more" accurate due to the fact that they can be moved to right before the throttle body so you are seeing the exact amount of air flowing into the intake manifold.
He has a GM 3 bar MAP sensor, there for a GM Maf will be easy to setup in DSMLink. It is almost impossible to set it up right without a MAP sensor. It can be done but thats the PITA way. Due to having to swap the stock mas in and out of the car to check settings.
I would go with the GM Maf and Translator.
Depending on how ported your manifold and o2 housing are, you wont see much of an improvement switching to an Evo mani.
You dont need a TT.
Lowering springs are up to you, depending on how the stock springs are for your liking.
J-pipe is pretty important if you have a hacked up one. If it doesnt leak then I wouldnt worry about it. But I'd definately test it to make sure.
V.C. elim is a waste of money also. Find a stock one for $15 online somewhere and have someone weld it together. Done. Also, what is the reason you are dynoing? If it is only to tune your car, find a buddy and go tune on the street. Nothing will change as far as your settings. You have everything a Dyno has. You have a wideband, tuning program, and you will actually get better intake temp's if you tune your car on the street. More of a better tune. Also, to think that it's not only going to cost you the $160 for the V.C.E. but then you have to pay for the dyno time. Waste of money if you ask me.
Only time I would ever use a dyno again is if I switch to AEM with dual fuel rails. Thats when it gets tricky to get the fuel maps correct. Brent Rau doesnt use a dyno, Shepherd doesnt use a dyno, as a matter of fact, Shep still screws around on the street when tuning. Think about that.
E-Klips is offline   Reply With Quote
Old 09-16-2006, 11:00 PM   #11
scottsee
Agreed... I'm been actively looking for a 2g MAFT setup with sensor for the last 2 days. Anyone know somone selling a complete setup for $150ish?
DSM geek
Old 09-16-2006, 11:00 PM   #12
Thor06
Jizzed In My Pants
Thor06's Avatar
Can you imaging taking 3rd gear pulls in that beast all day tuning? So where would Rau tune then, just on the track?
Old 09-17-2006, 05:57 PM   #13
E-Klips
Banned
He doesnt have that much to tune. More fine tuning than anything and its easy to do while running down the track.
As for all day tuning, he doesnt do that much, maybe 3 to 4 pulls at most and its 4th gear. 3rd gear is too short for the power band to log.
Old 09-17-2006, 10:43 PM   #14
scottsee
I found a 2 month old MAFT setup for $110. Should have it by friday.. I'm looking forward to the sound of my bov.. Honda's; watch out..
DSM geek
Old 09-17-2006, 10:46 PM   #15
Black99GST
Black99GST's Avatar
Send a message via AIM to Black99GST
get the GM Maft... only think on the list worth getting...
Black99GST is offline   Reply With Quote
