Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 09-29-2006, 11:39 AM
capriceowns capriceowns is offline
Pressed and floating piston pins
What exactly do these 2 terms mean, Im looking at pistons for my stroker, I ordered a Eagle stroker crank for 1 piece seal blocks and rods, and i found the 18cc dish top keith blacks giving me 8.7:1 with my 76cc heads(thats still pump gas right?)
I can order them with a floating pin or pressed, thats what I dont get.
1987 Chevrolet Caprice classic Brougham. 142,000 on the 305 and still chugging
Old 09-29-2006, 12:46 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Pressed and floating piston pins
Pressed means the pins are pressed into the small end of the rod. Floating means the pins are retained in the pistons with snap rings and the rod is bushed so that the pin can move around in it. Of course, this means the rods have to be prepared for the floating pins.
Stock pistons are pressed.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 09-29-2006, 01:04 PM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
There's a lot of perceived pros and cons to both conventions. Floating pins require more parts, more machining. They can also promote piston skirt slap since you have introduced another axis of motion into the mix. Some racers use coatings on the piston skirts to combat it.
Unless this is a race-only engine, you'll be gaining little by going to floating wrist pins.
Bob
Old 09-29-2006, 01:06 PM
Can I still order them as pressed? even if Im not buying the rods and pistons together.
