Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 08-19-2002, 02:39 PM
MattyO217 MattyO217 is offline
Talking How outta whack is/was your camber?
Please leave a response including model, drop, and camber after you dropped your ride. I just want to get an idea of what my camber will be after a 1.75" (front) and a 1.5" (rear) drop (using Neuspeed Sport springs on a 99 Si). Thanks for any input!!
~M
Old 08-19-2002, 08:32 PM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
I have my '00 Civic coupe dropped about "2 on a set of Tein SS coilovers. From other people that have seen it, my camber is about 2-3 degrees off. Enough that I more likely than not, need a camber kit.
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
Old 08-20-2002, 07:53 AM
CivicSiRacer's Avatar
CivicSiRacer CivicSiRacer is offline
Civic Mod
Send a message via ICQ to CivicSiRacer Send a message via AIM to CivicSiRacer
I'm dropped about 2" front and 1.75" rear. Camber is 1.5 negative front and 2.2 rear. I have 0 toe all around.
Sponsored by: KAM Racing Sports, Falken Tires, Finish First Polish, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes
Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO!
Autocross Help Page
Buy my Civic parts!
Old 08-20-2002, 11:48 AM
delsolsi delsolsi is offline
On a Delsol I used to have I had Intrax springs on it, lowered it about 2". My camber was between -1.5 degrees and -2 dergrees. Alot of people think that you need to fix this to keep your tires from wearing badly. This is wrong, these camber settings don't affect tire wear, and they make your car handle much better. The bad tire wear comes from toe not camber.
Old 08-20-2002, 12:42 PM
newciv newciv is offline
i have to disagree with delsol just because i have had alot of problems with it before. as far as camber is concerened anything over -2 degrees will make the inside of your tires wear out fast. -1 degree is what i would set my camber at its close to factoryy specs with no premature tire wear. toe is how the tires line up with one another .if your front tires are not straight with each other one tire will in actuallity be dragging across the road. id say if u put new tires on and your toe waas not set right those tires would not last a month before they had to be replaced.
Old 08-20-2002, 01:31 PM
Well I personally have not had any problems with this much camber and I know many other people that have not had problems this much camber. But if the toe is off the inside of the tire wears very badly. If you've got a protractor or something you can see degrees on look at the difference between 0 degrees and -2 degrees. The tire wear that results from such a small change is unnoticable.
Old 08-20-2002, 02:10 PM
Civic Mod
I disagree too. So if I put a platform shoe on your right foot and a sandal on your left foot you will not have any problems walking.
A combination of toe and camber affects tire wear. Please don't give bad information.
Autocross Help Page
Buy my Civic parts!
Old 08-20-2002, 06:56 PM
strodda strodda is offline
i think majority rules here. i had about -2 and the insides were bald in about a year.
Old 08-20-2002, 08:30 PM
What was your toe set at?
Old 08-28-2002, 04:47 AM
thebobs's Avatar
thebobs thebobs is offline
well shit. my 98 prelude SH is dumped between 2 - 2.5 inches, and ive got a 3 degree camber on one of the front tires. the back is better, about 1 degree.
Old 08-28-2002, 09:21 AM
nittanys1's Avatar
nittanys1 nittanys1 is offline
Send a message via AIM to nittanys1
I dropped my 99 accord sedan 2 in the front and 2 in the rear with eibach sportlines....and it was atleast 2.5 in the back...i dont have any problems with the front... but i went and got some control arms for the back and straightned it out but then it rubbed....so i baught some nuespedds, and pput them in the rear only so the rear is now 1.5 inches but i still rub...no biggy tho....
hey i finally got my kit put on ...check out my site and tell me what you think...sign the guest book too!!!
Old 08-28-2002, 10:13 PM
the toe was set correctly. got lucky though. when i had first lowered it, i didnt even think about toe. but only the rears were messed up.
