Go Back   Automotive Forums .com Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 02-20-2006, 02:09 PM   #1
the_game_rock
the_game_rock's Avatar
defrost froze???
My heat works but the furthest I can go with my knob that switchs between where I want the heat to go is between the floor and floor and defrost I can move the knob over all the way but it goes right back after I let go its like its hung up on something. It just snowed and iced and I got out of work after 12 hours of the car not running the problem started. Maybe something is froze up when I got in the car there was frost on the inside of the window.
the_game_rock is offline   Reply With Quote
Old 02-20-2006, 10:21 PM   #2
ice745
AF -Advisor
Re: defrost froze???
I'm not sure if the neon's controls are all electronic or not, but if the knob to select what vents are on moves a cable, the cable may need to be adjusted. When you try to turn it all the way to defrost and it goes back, do the floor vents still work? or just the defroster?
You can just take apart that part of the dash covering the controls, and see if you can adjust the cable or knob in anyway.
Just an idea :-/ Hope it helps.
Smoking is bad... especially blue smoke!
Fill the oil and check the gas, please.
ice745 is offline   Reply With Quote
Old 02-20-2006, 11:38 PM   #3
the_game_rock
everything but the defroster works it blows hot air and everything. it was messed up when I first tried to turn it all the way to the left but I kept doing it and it finally went it but I cant turn it all the way right
Old 02-21-2006, 08:41 AM   #4
das2123
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
I haven't heard of anyone having a problem like this before. I'd try taking off the HVAC controls and looking for any obvious problems.
das2123 is offline   Reply With Quote
Old 02-22-2006, 11:18 PM   #5
the_game_rock
Well I took off the plate for my knobs everything looks fine I took the top of my dash off and I turned the knob and seen a cable by the defroster I tried to move it with my hand to see if I could make it move but nothing I could hardly get to it so I guess tomorrow I may take the dash apart
Old 09-08-2006, 10:46 PM   #6
the_game_rock
found the problem the cable is bent right where it hooks up to the controls in the front.
Old 09-09-2006, 10:38 AM   #7
das2123
You ever finish your 2.4 swap?
2003 Dodge SRT-4
Old 09-10-2006, 08:46 PM   #8
skatendestroy
Send a message via AIM to skatendestroy
everything is cables and mark everythings position i still have a problem with feeling a draft through my vents when everythings off because the shutter in the box isnt lined up like it was.
skatendestroy is offline   Reply With Quote
Old 09-10-2006, 09:20 PM   #9
the_game_rock
nope not yet I started it without the grounds on and fried alot of crap. I have replaced the pdc box and the computer. Hopefully tomorrow. Ill post some vids after she starts. http://forums.neons.org/viewtopic.php?p=2052821#2052821 read that, that happened last night
