Go Back   Automotive Forums .com Car Chat > Chevrolet > S-10
Old 09-29-2006, 05:12 PM   #1
vtwindave
late 90's starter problem
a friend of mine has a late 90's s-10, has a new starter and battery, he still has an intermittent problem when starting, the starter seems to quit turning for a second or 2 then starts turning again. happened with old starter & bat. anyone ever run into this problem? (we're thinking maybe battery cables)???
vtwindave is offline   Reply With Quote
Old 09-30-2006, 08:46 PM   #2
sreve
Re: late 90's starter problem
yep, funky cables, bad connections can cause problems. the relay dropping out or a flashing security light?
clean up the connections, do a voltage drop check on the cables, swap out the starter relay w\another one in the box.
sreve is offline   Reply With Quote
Old 10-08-2006, 08:12 PM   #3
rhandwor
Take a 12 volt test light and pull the small wire fron the starter solenoid. See if you get 12v each time you try to start it. You could have a bad ignition switch. If you always get voltage check voltage at the starter you need at least 11 volt at the starter.
rhandwor is offline   Reply With Quote
