What type of flywheel to buy
Hello,
I need to buy a flywheel for a first gen 350. I visited the Summit website, and I noticed that there are steel and aluminum flywheels, with various weights (15-40 lbs. on average), different diameters and two different tooth count (153 or 168). I have no idea which one to buy. Perhaps someone can give me recommendations if I provide engine specs and application. Motor: 350 cid .040 over forged crank and rods 10:1 comp. 750 dp Holley Wieand team-g intake iron heads, 2.02/1.60 1.6 rocker arms comp cam 288 dur. .488" lift Muncie M21 close ratio 4 speed Car: 1962 Stratochief (similar to a Bonneville) weighs around 3600 lbs. gearing is not determined, somewhere around 3.73:1 street tires, normal diameter This vehicle is primarily for street use. Does anyone have any suggestions? Thanks. |
Re: What type of flywheel to buy
It is better to use a heavier flywheel on the street. Light weight flywheels ae generally used for racing when you want the motor to rev quicker.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1! 2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness! 1967 El Camino L79/M20 old school asphalt raper Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have. |
Look under the car at the starter bolting to the engine. If the bolts are staggered/offset you'll need the big flywheel. If the bolts are inline, direct across from each other you'll need the smaller flywheel. All steel flywheels are best for street use in general.
The smaller flywheel goes with the 10.375 diameter clutch and the bigger goes with the 11.00 clutch. But verify this with Summit, which might also impact your starter selection.
Stay away from the aluminum flywheels for street use. Aside from weight saving, there is no advantage and the steel one will outlast it by far. Bob |
The other thing to consider is whether the rear main seal is two-piece or one. The flywheels are different for each crank design. The 1-piece RMS design needs the "bat weight" in the flywheel since it is missing from the crank flange. What year is the block?
