Go Back   Automotive Forums .com Car Chat > Ford > Mustang > Mustang Talk
Old 10-30-2003, 12:10 AM   #1
stangfreak7
Send a message via AIM to stangfreak7
seat belt warning light
i was hoping someone could tell me how to fix my seatbelt warning light. i have a 94' mustang gt and when i first crank my car each morning, the seat belt warning light comes on and stays on, but then when i park it and come back to it hours later i can crank it and it works fine. i was wondering if anyone knows what the heck is goin on with it and if there is a way to fix the problem...thanks for tha help.
stangfreak7 is offline   Reply With Quote
Old 10-30-2003, 12:51 AM   #2
stang_racer20
stang_racer20's Avatar
Send a message via Yahoo to stang_racer20
were you not wearing your seatbelt when its on!?
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
stang_racer20 is offline   Reply With Quote
Old 10-30-2003, 12:45 PM   #3
stangfreak7
yes i have my seat belt on when it comes on. i cant figure out what is goin on.
Old 10-30-2003, 04:38 PM   #4
SkylineUSA
SkylineUSA's Avatar
Send a message via AIM to SkylineUSA
I am speaking off the cuff.
There should be 2 wires coming from the seat belt. Normally they form a short when the seat belt is engaged.
I would short the two wires together. I do not know for a fact. Normally I would get a multimeter in there and do some checks, but speaking from other cars that I seen, that is how they work.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
SkylineUSA is offline   Reply With Quote
Old 10-31-2003, 01:21 AM   #5
stangfreak7
thanks man, i will check that out in the morning, but y does it just stay on the first time i drive it??? if something was wrong like that, wouldnt it stay on all the time??? i dont get y it just lights up the first time i crank the car every morning.
Old 10-31-2003, 01:56 AM   #6
SkylineUSA
SkylineUSA's Avatar
Its a switch. They do weird stuff when the are not working properly.
Test it, and if that is not it, we'll go somewhere else down the line.
Old 10-31-2003, 04:20 PM   #7
Mendari
Re: seat belt warning light
Remove the switch from its location and give it a thorough cleaning with a toothbrush and WD-40. I had a similar problem with my hazard lights when a softdrink was spilled on it. It wouldn't work in the morning because the syrup was hard. But it worked later in the afternoon when the syrup had softened.
Mendari is offline   Reply With Quote
Old 11-06-2003, 03:34 PM   #8
stangfreak7
I havent got to checkin my switch yet b/c im not exactly sure what or where i need to be checking... the swithc should be in the seat belt buckle, right???
Old 11-06-2003, 03:56 PM   #9
SkylineUSA
SkylineUSA's Avatar
It will be in the buckle, the part that is mounted to the floor. There should be a couple of wires coming from it. Do you know how to ohms check it?
If not, go buy yourself a cheap little multi meter at radio shack, or home depot, and we'll teach ya
Old 11-06-2003, 04:15 PM   #10
Mendari
Oh Yeahhhh.
Time to break out the Multimeter and start probing. It shouldn't cost more than $15 U.S. dollars and you can use it for checking hearing aid batteries to rewiring wall sockets.
Old 11-07-2003, 08:38 PM   #11
stangfreak7
what should the ohm meter read when i have the car turned on and the light is on??? will it be showing power or not reading anything at all?? Sorry for all the questions, but i'm new to the switches and sensors of modern cars, im used to the simplicity of the 60's and early 70's muscle cars and jeeps.
Old 11-08-2003, 03:29 AM   #12
SkylineUSA
SkylineUSA's Avatar
I.am not sure about this switch, but how I check it would be to isolate the switch. Follow the wires from the seat buckle, there should be a connector somewhere under the seat. Disconnect the wire from the rest of the circuit. Where you have it disconnected, hook the multi-meter leads to the side of the connector that is coming from the buckle. Turn the multi meter into the ohms position.
(Ohms is a reading of resistance, meaning if its an open you will read an infinite amount, take the leads and place them together, this is a short, this is where you should zero ohms. Never apply voltage to a multi meter that is in the ohms position.)
Not sure if you should read a short or an open, but I would think it should be a short, when you click the seat belt into the buckle the multi meter should go to an open. It could be vice versa.
This is how I would check it.
If the light is on, I would think there is a voltage on the line. But, every circuit can get the same result, but it electrically different
