E Ram
i cam across this site and was wondering if anybody has ever heard of this and or knows anything about it. they say for turbod applications it is supposed to help the turbo lag a little, but i dont know, thats why im bringing it here.
i think its a little spendy though http://www.electricsupercharger.com/
93 hatch W/SR20 BLKTOP, FMIC, blitz BOV, tien coilovers, rsr exmag exhaust, downpipe, wallboro fuel pump, custom oil cooler W/ ebay oil filter relocation kit. apexi afc neo next upgrade = z32 brakes all around 210 hp/215 tq to the wheels |
Re: E Ram
15 hp for $300 is not horrible, but id be turned off by the extra drain on the battery/alternator, and the extra parts needed
Re: E Ram
Does it actually work? Ive seen places on the web that say theyve tried it and it did nothing that the dyno could see... pluss they always seem to look cheaply made to me...
1992 Mitsu 3000gt sl 5sp - High flow filter - Pioneer head, dual 10's - H4 headlight conversion - Throttle Body Spacer - The "For God's sake stop that infernal buzzing" mod - LED "Snake Eyes" - Lightweight Crank Pulley -More to come- ![]() Your 3000GT is the 5095th out of 6964 . Only 41exactly identical Bloody Knuckles from Changing Fuel Filter Crew Member #1 |
Re: E Ram
I run two in my car. Since you can run them in series you can run as many as you want really. Performance gain is amazing and dyno proven! 30hp!
Re: E Ram
SHIFT_S i d e w a y s Quote:
Re: E Ram
Re: E Ram
-Matt NISMO ![]() 1992 240sx SE Fastback 5speed ![]()
Re: E Ram
Re: E Ram
REALYY?? i dont mean to be a prick but i dont hink anybodys gonna take your word for it
Re: E Ram
well, i might try it sometime in the near future when i can spare 300 bucks, if i do ill let you guys know how it works out
Re: E Ram
Re: E Ram
Re: E Ram
Spend 300 bucks, or you could just build your own. The idea is simple enough, I've thought about doing something similar for just shits and giggles on a few cars of mine.
I highly doubt 30HP. Now if you did a RAM air set up with somthing like e-rams I could see maybe a bit more.. Forcing the air over the fans, and the fan motors would be able to reach higher RPM ranges allowing the fans to spin faster, hence adding more power that way. But even still. 300 bucks? Grab a turbo if you're going to spend that much money in to force injection system. |
Re: E Ram
if you have a turbo car it would do something. an eram is just a fan built to reduce "turbo lag" the time it takes to spool up the turbo. does add low rpm power for turbo cars by spooling up the turbo faster... it does not make boost! this is not an electric turbo, its a fan. does not give na cars power. if you hook one up no an intake it will just restrict your airflow at high rpms.
