Go Back   Automotive Forums .com Car Chat > Land Rover > Series II and III
Old 09-22-2005, 01:18 AM   #1
zombi
1959 series 2 109 5 door for sale
Lots of work done very clean frame and bulkhead(some rust in drivers foottwell (very minor)). New brakes all round(shoes, lines, wheel cylinders, master). Rebuilt clutch master and slave cylinder. Relined fuel tank. New battery, cap, rotor, condensor, points, plugs, coil, hoses, belt, distance pieces(what the seals ride on on the axles), axle seals. Nos rear hub, sparto tailight lense. New u-joints in front drive shaft. The original engine runs fine(could use the valves set). The original dated radiator was boiled and tested. New fluids in everything. All guages work and even the horn. It was sitting for ten years before so some debugging will have to be done. It runs and drives great but not daily driven for 10 years. It is a rare poppy red color(in 1959 they reserved that color for fire trucks etc). Still wearing its elephant hide interior. This is a north american spec vehicle as it was originally sent to vancouver BC. Lots of pics email [email protected] for pics. Much more done but can't remember evrything at the moment. The bad it needs a front bumper, needs the little bit of floor work on drivers side, the passenger side wiper doesn't work(might just need a cleaning), there is a little bondo on both sides of the truck, the drivers side fender at the top was cut to gain access to the master cylinders I assume, an interior.
The truck is in Lloydminster, Alberta, Canada.
zombi is offline   Reply With Quote
