Go Back   Automotive Forums Car Chat > Mazda > 323/Protegé/Familia/Etude/Allegro
Old 08-01-2006, 08:17 PM
95supreme's Avatar
95supreme 95supreme is offline
Angry No Turn Signals or Hazard lights...
I installed a new car stereo today, a new Kenwood to replace the factory deck.
I got a wiring harness, and then connected the following wires that Kenwood needs:
Red ignition
Yellow 12v constant
Ground
Speakers
The positive dimmer and illumination wires had no connection available to the Kenwood deck.
The stereo works great, but now there are no signals or hazard lights?
I checked all the fuses inside the car and under the hood, nothing blown. I have a Haynes manual, and can't see anything else to check.
Please help!
Thanks in advance.
Old 08-02-2006, 06:16 AM
Flash75 Flash75 is offline
AF - Advisor
Re: No Turn Signals or Hazard lights...
Have you tried unhooking the stereo to see if your lights will work? If they work with the stereo disconnected something in the stereo is causing the problem, probably too much electrical load in the red circuit. Maybe you can find an alternate place to pick up the red ignition?
Clifton
Old 08-02-2006, 12:07 PM
95supreme's Avatar
Hi Clifton,
We did try unhooking the stereo and the signals and hazard lights still do not work. Rechecked all fuses and none are blown.....
Old 08-02-2006, 01:53 PM
AF - Advisor
OK, that clears the stereo as the problem source. At this point I would use a multimeter or test lamp and chase the circuits. I don't have a wiring diagram or a book for your car, is there a circuit breaker for the signal lights? Check it if there is one, Check for 12 volts in the circuit beginning at the fuse box. You could have a defective hazard flasher, the turn signals go through the hazard flasher on most cars. Hope this information helps you on the right track. Good luck.
Clifton
Old 08-03-2006, 02:46 AM
stamar stamar is offline
if you have no turn signals or hazard lights youve killed something called the blinker box or flasher unit.
now wouldnt it be so useful if I told you exactly where iit was, seeing as I have a 95 protege and the chiltons manual?
Well I dont know couldnt find where it is. most likely it is in the drivers side pedal area near the fuses themselves. any reason why you may have pulled a fuse from the flasher box?
two different fuses for turn signals and hazard ok, so unless both are out you can eliminate fuses, both go to the flash unit. thats your proble, good luck
97 sentra gxe auto 174k miles
89 nissan d21 truck z24i 213k miles ( with a cabover camper)
