Go Back   Automotive Forums .com Car Chat > Buick > Park Avenue
Old 11-11-2002, 01:16 PM   #1
tegger
Send a message via Yahoo to tegger
92 Park Ave.
Lately my 92 park ave. has been having a starting problem! When you turn the key it starts but stalls right away! I turn the key again and it starts, but tends to smell like gas for a short while! What could be the problem? Thanks
tegger is offline   Reply With Quote
Old 11-11-2002, 05:08 PM   #2
tman
Pimpin' ain't easy
tman's Avatar
Send a message via AIM to tman
mine does something similar to that. My unlce says to tighten the bolts on the valvepan cover.
tman is offline   Reply With Quote
Old 01-21-2003, 06:56 PM   #3
KEVINS800
your fuel presure regulator is most likely bad!! run the engine then shut it off, then pull the vacumn hose off the fuel presure regulator. check to see if gas is comming out the vacumn line! if there is gas> then replace the fuel presure regulator.
KEVINS800 is offline   Reply With Quote
Old 01-21-2003, 07:01 PM   #4
Melt
Melt's Avatar
Send a message via AIM to Melt
I also think its probably your fuel pressure regulator, friends park ave had a similar problem.
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Melt is offline   Reply With Quote
Old 01-21-2003, 08:10 PM   #5
tegger
It was a cracked short hose to the regulator. I replaced the hose, no more problems! Thanks
