Go Back   Automotive Forums .com Car Chat > Oldsmobile > Alero
Old 07-27-2006, 03:58 PM   #1
blandon7
Low noise heard while driving....sometimes
Subject is a 2000 V6 Alero with 85k miles. Starting yesterday afternoon every so often there is a low pitched noise, almost like a squeel heard coming from the front end while driving. The noise happens while the car is traveling down the road but it isn't a constant noise though. Only occurs for maybe 20 or 30 seconds total out of a 15 mile drive. I have noticed that if I lightly tap the brakes while the noise is present the noise gets worse. This could be brake pads getting wore down but I'm not totally convinced of that. Could it be the CV joints? Any ideas?
Thanks
blandon7 is offline   Reply With Quote
Old 07-27-2006, 04:27 PM   #2
BNaylor
BNaylor's Avatar
Re: Low noise heard while driving....sometimes
CV joints normally do not make that type noise. I would say disc brake wear indicator causing the squeal but you could have wheel bearings wearing out too. Wheel bearings are part of the hub/wheel sensor assembly. The brakes are easier to work on and should be illiminated first as the possible cause.
Timeslip 08/12/06
AF Community Guidelines
BNaylor is offline   Reply With Quote
