Go Back   Automotive Forums .com Car Chat > Buick > Century
Old 05-31-2005, 01:53 PM   #1
terrapin24h
1996 Air conditioning removal(sort of)
Hi all--
Here's the situation: My father in law has a 1996 Buick century with a shot AC clutch- squeals like a stuck pig all the time, metal shavings on crossmember underneath it- Money is VERY limited, and i was thinking the cheapest way to fix it would be to simply take the AC compressor out of the belt run, by putting a belt on the thing for non AC equipped models of the car/engine, bypassing the ac compressor. I figured a wrecking yard or at worst a parts store would have what i need. Questions is, will this work? Obviously im gonna have to route the belt to all the other stuff(crank, steering, h2o pump, etc) Anyone done this before? Or am i spending more money by doing this and not just getting a new clutch for the compressor ? I've done a decent amt of wrenching in my time, but funny enough not on AC systems(truthfully none of mine ever broke) TIA for the comments
--chris
terrapin24h is offline   Reply With Quote
Old 05-31-2005, 07:14 PM   #2
GTP Dad
Pontiac Guy
Re: 1996 Air conditioning removal(sort of)
You would be better off going to a wrecking yard and finding a new/used compressor that you can replace the old one with. I don't know what size engine you have but try this: http://www.car-part.com/ I found one for less than $80 at a wrecking yard in NY state. You will probably save time and money this way and nothing says you need to have it recharged!
GTP Dad is offline   Reply With Quote
Old 05-31-2005, 08:18 PM   #3
Flatrater
Main GM Guy
Flatrater's Avatar
All I would do is adjust the air gap on the AC clutch. Then see if the AC blows cold. You could fix your problem without buying any parts.
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
Flatrater is offline   Reply With Quote
Old 06-01-2005, 06:54 AM   #4
GTP Dad
Pontiac Guy
I agree with you Flatrater but if he is throwing metal shavings all over then it may be too far gone for that to help. Of course it is worth a try!
Old 06-01-2005, 07:59 PM   #5
Flatrater
Main GM Guy
Flatrater's Avatar
You can always just replace the clutch which would be cheaper than the whole compressor. I have done several throwing metal shaving and I fixed them without any parts. Just depends on how long its been doing it.
ASE Master Tech
ASE Advanced L1
GM Master tech
Old 06-06-2005, 12:52 PM   #6
terrapin24h
Re: Re: 1996 Air conditioning removal(sort of)
Flatrater--
thx for the replies, can you jot a quick procedure for adjusting the air gap?(My FIL doesn't mind the idea of not having ac which is why i was thinking the belt route, just leave the compressor sit there dead) At this point it's been doing it a while(over two weeks) and he claims the noise is getting quieter(i'll assume that's because the innards of the thing are disappearing). I have another question: if i decide to just replace the clutch, can i tell if the compressor is locked up/shot by turning the shaft with a wrench or some channel-locks? My inclination would be that under normal conditions there's too much pressure there to man-turn it, right? I just don't want to get a clutch, come back put clutch on, re install to find out that the compressor is shot. Now i have to reverse what i did and go get a compressor. Any ways, if you guys could let me know what you think the best route is, i'll prob get roped into working on it this weekend, maybe sooner. thanks again!
Old 06-08-2005, 07:29 PM   #7
BuDog
I think that all Century's come standard with A/C and you won't find a belt that will work correctly by bypassing the bad clutch/compressor. Probably better off getting a junkyard clutch and compressor that isn't seized up.
BuDog is offline   Reply With Quote
Old 01-31-2006, 03:37 PM   #8
96 GT
For anyone else with this problem, you can use the diagram for running the belt without AC , but you need to get a belt for a buick SKYLARK with the 3.3 V6..I had the same problem while driving to Texas , so a quick fix was necessary. They didn't have a belt for the Century because they all came with AC standard. Hope this helps anyone else..
96 GT is offline   Reply With Quote
Old 07-04-2006, 10:45 AM   #9
kmarina
Smile Re: 1996 Air conditioning removal(sort of)
I have a 1992 Buick Century 3.3 with a bad air compressor. I followed the diagram that shows a serpentine belt without an air compressor and used Goodyear Gatorback belt number: 4060735 6PK1865
kmarina is offline   Reply With Quote
