Old 06-22-2006, 04:42 PM
71satelite 71satelite is offline
95 Camaro Theft Deterent System Problem
Hey folks new here, I recently purchased a 1995 Camaro for my sons first car (lucky him). It is a 3.4 V6 model, standard shift. The price was right because it came with a problem. The vehicle won't start. The previous owner said that a mechanic looked at it and said there was a problem with the theft deterent system not allowing the car to start. It had just come from getting new tires put on and when it was parked it wouldn't restart. I saw some stuff on this site about how to by pass this for remote starters which seems simple; however I desire to keep using the key. Question is how do I get around this or how do I trouble shoot/repair this?
Old 06-22-2006, 05:58 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: 95 Camaro Theft Deterent System Problem
Does this car have a aftermarket alarm or are we talking about vats here?. Cause vats is easy enough to bypass. Will cost you all of maybe 50 cents in parts.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 06-22-2006, 07:51 PM
Ok I did a little more research and testing and I think my key has to high of a resistance value. How can I find the original value?
Old 06-22-2006, 08:27 PM
FormulaLT1's Avatar
Fight the powwa!!!
Take the key to any GM dealership and they will tell you the number/resistance of the key. Whatever you do, DO NOT BUY A VATS KEY FROM A DEALERSHIP. They will rip you a new one. Take the value they give you and order a blank vats with that value off of ebay for like 6 bucks shipped and then get it cut at any locksmith for 2 -3 bucks. Its much better than the 35 - 65 the dealers charge.
Old 06-22-2006, 08:33 PM
stepho stepho is offline
Send a message via AIM to stepho Send a message via Yahoo to stepho
If you take your title and your key they will be able to tell you if the resistance is correct.
Originally Posted by sportlinetta
lol, u guys are dummmmmmmmmmmmb im 14 n i know more. i gotta 88 camaro.
would that mean get a new cylinder or plug???
Old 06-23-2006, 07:18 PM
Well guys this was the outcome, the battery was dead so I had to hook up the battery from my car and everything came on like the car was going to start... However no start, no attempt to turn over even. All I had was the binking security light. When I measured the resistance of the key I came up with 1.8K Ohms which was in specs with a chart I found which would make it a number 7 key. What is my next step? I think, and you can tell me if I am correct, is to check the two wires coming from the ignition. Put the key in the ignition and turn to start, cut the wires and measure the resistance of the circuit with the key in place. If the resistance is way off from what the key is the ignition is bad. Do they sell these resistors at the part stores or is this a dealer item? Thnaks for all the help guys this my first Chevy I have worked on from this age. Usually is one of my buddies and its the older stuff. We are taking my buddies Malibu with the 396 to the track tomorrow to see how it does!! Let me know you guys are great!!
Old 06-23-2006, 07:37 PM
FormulaLT1's Avatar
Fight the powwa!!!
Radio shack sells them for pretty cheap.
Old 07-02-2006, 09:50 AM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Sort of. Your steps are what you do with the newer passlock stuff. You don't have to crank the car over, just insert the key all the way. Then, go to the bottom of the colum and find the VATS wires which will be in an orange tube. Follow it down further and you'll find where you can unhook the harness. Meter those wires on the "key" side. It should match what you said the key is. If it doesn't, that's your problem. Easy fix is to get a resistor and connect to the VATS wires going to the computer. If you can't get the resistance right on, try to go a little higher instead of lower in value. I've seen problems if you go a little lower but going a little higher usually works fine.
Silverado Ext. Cab 4x4 z71
Pioneer 4900mp
Orion P6.2 Componet sets front
Orion C63 Coax rear
DirectedVideo 9" all in one DVD with surround
2007 SATURN OUTLOOK AWD XR with full entertainment package
