Go Back   Automotive Forums .com Car Chat > Nissan > Primera | G20 > Maintenance
Maintenance problems, fixes.
Old 04-01-2001, 03:00 PM   #1
Koojo
Koojo's Avatar
Send a message via AIM to Koojo
I have few little spot of rust on my alloy/aliminum rims, anyone know how to get rid of them without damaging the rest of the rims?
Please fill in what Brand or model of the product is the best for the car-
Oil:
Oil Filter:
Air Filter: (Anyone know if K&N are available)
Fuel Pump:
Car Wash Liquid:
Polish:
Wax:
Rim/Tire Cleaner:
Tire Sizes: (I read that you could but 205/60/15, but not sure.)
Leather and Inside Plastic Cleaner:
Carpet Cleaner: (regular ones?)
Brake Pads:
Thanks so much :smoka:
Koojo is offline   Reply With Quote
Old 04-01-2001, 11:18 PM   #2
Kenny-G
Send a message via ICQ to Kenny-G
You have rust spots on the wheels of your 2000 G?....I would just use some sandpaper and sand the rust out than apply some clear coat on it.
Oil--Mobile one 5w-30
Oil filter--I use Nissan filter, it has beefier body.
Air filter--I use K&N drop in. If you don't find the application for your car than try 97 200sx SE-R.
Fuel pump--???what is fuel pump
Car wash, polish, wax--I use Turtle product, specially their wax with cleaner is awesome.
Rim and tire cleaner--I just use the car wash water to wash my rim, yeah I have the 16-17 spokes rim, it is a pain. I don't even use tire cleaner.
Tire size--205/55/15 is the upgrade size of 195/60/15, yeah you can go 60 series but...side wall would look fat. I use Brigestone Potenza RE 730, it sticks.
Carpet cleaner--I use 409....
Brake pad--Metal master is great. If you can't find the application for 2000 G, then go 96 Nissan Maxima, they use same pad.
Leather clean and conditioner---I am still trying around.
Anything else?
:smoker2:
Kenny-G is offline   Reply With Quote
Old 04-02-2001, 03:55 PM   #3
Koojo
Koojo's Avatar
I live in Vermont and it snows a lot here in the winter, and there is salt all over the roads. There arents a lot, but theres like 2 or 3 little dots of rust on one rim.
I have a 00 G20, and they came with the 195/65/15. You were talking about the 195/60's. You think the 205/55/15 upgrade will work for my 195/65/15? Thanks
Old 04-02-2001, 04:05 PM   #4
Kenny-G
Yeah 205/55/15 would be fine. From factory 195/65 is standard on G20, and 195/60 id standard on T model, but the speedometer setting is the same. So there is a little bit error on the reading to begin with on either one of the model. By upgrade your in 205/55 you would gain steering response, improve acceration due to small overall diameter of the tire, but your speedometer would show faster than you actually going. And 55 series is a better idea performace-wise because most of the high-performance tires are made in lower sidewall ratio, so you have more applications to choose from. Oh, my tire cost me 90 bucks a piece and 20 bucks for shipping of all 4. Not bad. Plus installation and balance of course.
Old 04-02-2001, 04:09 PM   #5
Koojo
Koojo's Avatar
Ya the 205/55 gives me more choices, I thought that I could on put on 205/60, and there werent too many of those that I was interested in. I will probably check around in the local stores for teh tires, but I dont need new ones yet since my car is less than one year old. Maybe next year I will get some. Thanks man
Old 04-02-2001, 04:20 PM   #6
Koojo
Koojo's Avatar
Air Filter:
I just checked the K&N Filter calalog online, and I looked at both the g20, and 97 200sx 2.0L. Both of them use the filter number 33-2031-1. The problem is that the catalog online lists the g20's up the the year 1996. You know if I can still get one for my 2000? Maybe the catalog is old or something, but I dunno since it lists a 99 I30 bellow the G20. Thanks
Old 04-02-2001, 04:26 PM   #7
Kenny-G
You know what you can do. Go to a autopart store, like Al's....if you still have Al's over there...look at there air filter application chart to see if they use the same filter for 2000G and 97 200sx SER.
The filter works on my 99 but you have a 2000, they have done a minor change to the intake manifold so I am not 100% sure it use the same filter.
Old 04-02-2001, 04:29 PM   #8
Kenny-G
And air filter for 91 to 96 G does not work on P11
Old 06-07-2001, 03:01 AM   #9
napakapa
Send a message via ICQ to napakapa Send a message via AIM to napakapa
I have a 2000 G and i got the K&N drop-in on mine. It fits perfectly, they have it at Kragen and stuff from like around 40 bucks
napakapa is offline   Reply With Quote
Old 06-07-2001, 11:29 AM   #10
Koojo
Koojo's Avatar
napakapa....whats the model number for the k&n drop in filter for your 2000 g?
Old 09-10-2001, 04:20 PM   #11
howard_w13
howard_w13's Avatar
Lightbulb Wheel & tire upgrade
Since you want 205/55 tires, it would probably be better to go up to a 16in wheel/tire combo. The bigger wheels would give your car a more aggresive look.
howard_w13 is offline   Reply With Quote
Old 09-10-2001, 04:40 PM   #12
freaktroll
Air filter (K&N)
Just wanted to let you know that im pretty sure they make a drop in filter, but if you want a little more performance and some better sound, you should go with the JWT or Stillen POP charger. There are some pics of these on my website, and a link to how to install them. Basically it replaces your filter box, and mounts right to the airflow meter. They run a little more (because you are getting more than just a filter). You can also check them out on these websites too...
www.jimwolftechnology.com
www.stillen.com
The majority of the modified G20's have these cone type intakes (and it adds about 4-6 hp supposedly)
Good luck!
JP
Visit THE Clean G @
freaktroll is offline   Reply With Quote
Old 09-11-2001, 02:16 AM   #13
napakapa
for the 2000G and i think for all years, it is 33-2031-2 K&N drop-in
Old 09-11-2001, 06:53 AM   #14
P10DET
P10DET's Avatar
Dude....
Aluminum doesn't rust.
George Roffe
Houston, Texas USA
00 328i
91 SE-R (well modded)
84 944 SCCA ITS race car under construction
"I fear all we have done is to awaken a sleeping giant and filled him with a great resolve"
-- Admiral Yamamoto, December 7, 1941
P10DET is offline   Reply With Quote
Old 09-12-2001, 01:36 PM   #15
kenchan
kenchan's Avatar
aluminum does corrode into alike a green/white kinda color.
i drove around my G throughout the winter last year in heavy salt myself in chicago, but no rust. you sure it's rust and not a clump of brake dust contamination? if it's brake dust, use some cleaner wax. i'm sure you already know this, but make sure to wax your wheels with decent wax before the first snow fall. meguires cleaner wax tends to bond to the surface longer than regular goldclass wax for some reason.
if you use sand paper, touch up with clearcoat afterwards.
yeh, just go to the store like kragan or autozone and ask the clerk to list up the KN filter for the 99+ . they all fit, got one on my 01'.
1998 Prelude SS - TEIN HA with upper pillows, SSR Integrals 17x7 with SP8000 (215/45), GReddy Evo catback, Iceman Comp Intake, DC Sports header, Apexi VAFC, ZEX 55 shot with bottle heater, NOS blanket, Factory Body Kit, Spoon F/R tower bars, JDM Foglamps, Carbon Fiber trim, Razo pedals &knobs, Fiamm Dual air horn
Future Mods: Lighten car, 2nd 10lbs nitrous bottle would be nice too.
2001 G20 P11 AT- TEIN NA, TRM Snipers 17x7 with Potenza RE910 (215/45), Arospeed Dual-outlet Muffler, K&N Drop-in Airfilter, WW Front Lip, Nakamichi MB75 1DIN 6CD Changer/Receiver, FIAMM Dual Air horns, Levoc Pedals, PIAA (H4 Superwhite H3 Ion Crystal, 168 SuperWhite)
2002 WRX MT- TEIN HA's with upper pillow mounts, 1000Miglia HT3 17x7 with sumitomo HTR+ 225/45/17, painted side skirts, Cusco front & rear strut bar, Whiteline rear swaybar, aluminum endlinks, Blitz NUR Catback, HKS seq. BOV, factory front lip, rear valance, Kartboy short shifter and bushings.
Future mods: dressup wheels with Potenza S03 225/45/17 tires, TurboXS UTec, maybe an uppipe. by then, it'll be fast enough.
fiamm dual air horns.
kenchan is offline   Reply With Quote
Model Car Parts/Accessories? dunne08 Car Modeling 17 06-01-2011 08:07 AM
Accessories & Parts Womper_1 Car Modeling 4 03-25-2011 05:41 PM
I need help with my Sluggish 1984 Chevy G20 Van (skill level low to intermediate) Rafael Rivera Chevrolet Classics 7 08-06-2010 06:59 AM
Accessories Not Getting Power!!!!! Redneckboy360360 Silverado 8 01-18-2010 07:56 AM
