Go Back   Automotive Forums Car Chat > Honda > N2O | Turbo | Superchargers
N2O | Turbo | Superchargers Tech forum to assist in Honda/Acura Performance.
Old 06-17-2006, 01:45 PM
fiberglasscivic's Avatar
fiberglasscivic fiberglasscivic is offline
Send a message via AIM to fiberglasscivic Send a message via Yahoo to fiberglasscivic
Internal Wastegate to External wastegate
Is there any way to make a turbo with an internal wastegate operate on an external wastegate?
AF COMMUNITY GUIDELINES
Old 06-18-2006, 01:58 AM
iVteC_PoWeR iVteC_PoWeR is offline
Send a message via AIM to iVteC_PoWeR
Re: Internal Wastegate to External wastegate
im not extremely 100% sure on this one but pretty confident this is right...yes you can run an external wastegate even though your turbo is loaded with an internal...to my knowledge youd weld the spring on the internal wastegate shut and make sure your turbo manifold has a flange for an external wastegate and run it from there...now the part im not too sure on is how to shut down the internal wastegate but im almost positive thats how to run the external wastegate
Old 06-18-2006, 11:07 AM
I just recently read somewhere that you remove the wastegate from the turbo and weld a plate in its place. Anyone know if that works or not?
Old 06-20-2006, 02:26 AM
nitebeest nitebeest is offline
I think thats pretty much what ivtec is talking about. welding the internal closed and then run an external from an external wastegate flange.
Old 06-20-2006, 05:25 AM
Are internal wastegates as easily controlled and upgraded as external?
Old 06-20-2006, 02:21 PM
you can run more boost with the external
Old 06-22-2006, 01:09 AM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
all you do is weld (or somehow hold) the internal gate shut and run it as a standard turbo. You can get a 5 bolt flange for your DP that covers the flapper hole and disables it, you could pull the actuator arm off of the internal gate, or just weld 'er shut and you can use external...
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Schister66's Avatar
AF -Advisor
not necessarily, but you can better control your boost settings and prevent boost creep.
Old 06-22-2006, 01:17 AM
What exactly is boost creep?
Old 06-22-2006, 01:19 AM
Schister66's Avatar
AF -Advisor
you have a wastegate spring (in my case for example) that is set for 10psi. I only want 10psi and that's all i'm tuned for. Boost creep occurs when more that 10psi reaches the turbo and therefor is translated into more than 10psi in the charge side.
Manifolds and WG's both play a large roll in controlling boost creep.
Old 06-22-2006, 01:25 AM
How does the mani help control boost creep? I understand how the WG would.
Old 06-22-2006, 01:28 AM
Schister66's Avatar
AF -Advisor
the placement of the extension for the wastegate is the main reason. Drag manifolds have the WG placed on the first runner...the first runner's boost level is controlled, but the rest of them aren't. The manifold creeps a lot. A good example is the InlinePro manifold (for cast anyway) because the WG is located over the collector and that is the best place for it.
Old 06-22-2006, 01:31 AM
Center versus runner like you said in your 'How To'
Old 06-22-2006, 01:34 AM
Schister66's Avatar
AF -Advisor
yep
