Go Back   Automotive Forums Car Chat > Chevrolet > Cavalier > Cavalier Problem Diagnosis
Old 09-22-2006, 01:12 PM
cwilson_36 cwilson_36 is offline
extremely fast idle
why is my car idiling so fast?
i recently replaced the injectors in my car and now the car goes straight to 5000 rpms on startup. i have a custom chip to handle the larger injectors, i have no vac. leaks, everything is hooked up correctly, replaced the tps and iac even know everything was fine before and still nothing helps. i'm all out of ideas. PLEASE HELP!!!
this is on a 93 3.1 cavalier
Old 09-22-2006, 07:16 PM
Cold_Silence's Avatar
Cold_Silence Cold_Silence is offline
Send a message via AIM to Cold_Silence Send a message via MSN to Cold_Silence
Re: extremely fast idle
Did you put larger injectors in? Did this happen before the injectors and the chip? Do the revs drop after 5k on startup?
I personally dont like chipping cars, that could be farting with the ECU and making it run funny. Try putting the old injectors in if u have them, if it still does it, pull the chip and try it out.
The New Ride!! 2002 Cavalier Coupe..
Originally Posted by noshun
It's a lovely 2200, but got about as much poke as my grandma with no fingers.
www.cleanstartsolutions.com
Old 09-22-2006, 07:24 PM
swapped in diff. chips. all had the same results.
now the update:
earlier i took everything back apart just for shits and giggles. either that or it would've just sit. well again everything was fine, o-rings, injectors seated properly. however the only thing i noticed was the pvc hose end where it actually connects to the pcv was connected, but slightly crooked. put everyting back together and walla.
NEW PROB:
now the car ran rough for a litttle while and eventually leveled off which is expected, but it' still is around 1500.
Old 09-22-2006, 07:33 PM
husker cp husker cp is offline
Leaking GMC Sonoma (Extended Cab Windows)
Anyone with experience replacing the weatherstripping on the "foldout" windows" with the extended cab trucks. My son has 91 Sonoma and the rear windows are leaking. I used some "goop" as recommended by a local auto glass shop, this slowed the leak but did not stop. Am I best leaving this to a professional?
Old 09-22-2006, 09:08 PM
Re: Leaking GMC Sonoma (Extended Cab Windows)
Wrong forum, n make a new thread if u want it answered in the Sonoma forus. Thnx
