Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 08-14-2006, 11:28 AM
Mark Fowler Mark Fowler is offline
Question 89 Ranger Cant find Mass Air Flow Maf Sensor
I have been intermittantly getting a check engine light. I checked the codes with a volt meter and it's reading 66 for MAF below minimum voltage. The vehicle has a date of 12/88 on the door. The air intake tube is one rubber tube going from the air filter to the intake, and there is not a section for a maf. I'm wondering if the vehicle was out before the maf was added, or if maybe someone removed it before i got the vehicle. Does anyone know where i might find the maf?
Old 08-14-2006, 11:45 AM
Re: 89 Ranger Cant find Mass Air Flow Maf Sensor
Oops, it's the 2.3 liter with the manual 5 speed, and air conditioning.
Old 08-14-2006, 11:54 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Clear and recheck codes no.
I do not show a 66 code fot that year and engine.
MT
MT
Old 08-15-2006, 01:30 AM
Lightbulb Re: 89 Ranger Cant find Mass Air Flow Maf Sensor
Thanks for your help!
Apparently it was a 67, neutral drive switch (nds) circuit open with a/c on during self test. not sure what that means, but it does not sound terrible.
I had a value of 21 for the engine coolant temp (ect) out of range, replacing that sensor made a lot of difference, runs smoother and has 'some' acceleration in OD now. Hopefully that will make my 18 mpg increase to 25 or more.
The codes i get when running are 15 and 41.
15: eec processor (keep alive/read only memory) test failed.
41: HECO (ho2s-2*) sensor circuit indicates system lean.
Not sure what to do with those, maybe they are not a big problem.
It's possible those codes are wrong, but it's around 2am and the ranger kept setting off a roommates car alarm, so i did not test again.
Old 08-15-2006, 08:38 AM
MT-2500's Avatar
AF - Advisor
The code 41 lean codes needs worked on or rechecked..
But first clear all codes and drive and recheck.
MT
MT
