Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 2nd Gen 00-05
Old 06-07-2006, 10:48 PM
smitty42 smitty42 is offline
installing a tach on 2000 neon
What do I have to do to insall a tach and how much work is there to doing it.
Old 06-07-2006, 10:54 PM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: installing a tach on 2000 neon
It would be easier to install a cluster that already has the tachometer in it.
Old 06-07-2006, 11:04 PM
cluster? no i would rather have a nice fat tach man on the dash and my car dosent come with one stock how much work is there? and i was talking to some guy he said i need to buy some part before i throw one in. if anyone with one in there neon has instaled it them self please tell me what u did to put it in and if i do need to buy an extra part
Old 06-08-2006, 12:07 AM
FemaleRacer FemaleRacer is offline
Cool Re: installing a tach on 2000 neon
das is right, It would be easier to install a cluster that already has the tachometer in it. Why would you perfer the tech man? Just honest curiosity
Don't let the 34JJ's and 6" heels throw you off...I race to win. No games. Just you in my rearview mirror
Old 06-08-2006, 09:32 AM
HPNOTIQracing HPNOTIQracing is offline
because he likes the big tach in the middle of his dash.
its not my thing but alot of people like it. as apposed to having one on the cluster. hell i know alot of people who have even tho they have one on the cluster.
ok most tachs come with 4 wires.
1 wire is for your constant
1 wire is for your ground
1 wire is for your backlight
1 wire is for tach signal
constant wire goes to a power supply that only comes on when you turn the car on. usually a fuse in the fuse box is used.
ground goes to a ground
backlight wire goes to the wire that illuminates your cluster when you turn on your headlights.
and tach signal wire goes to the tach signal wire.
if this was a first gen i could tell you what wires you needed to tap
sinse its not your gonna have to get a haynes or find it on the internet somewhere.
Old 06-08-2006, 10:54 AM
neon_rt's Avatar
neon_rt neon_rt is offline
You will need a tach adapter. You may need to do a search on the Forums, I've seen this subject discussed before. There isn't a signal that you can just "tap" into on the neon ignition, there is no distributer. I think it is MSD that makes an adapter to read the signals going to the coils and translate them to a standard Tach signal. Even though there is a Tach signal going to the wiring harness that connects to your present cluster, you can't use it because it is a proprietory digital signal specifically for the factory cluster.
Old 06-08-2006, 12:37 PM
is that a second gen thing because that is not an issue for the first gens afaik
Old 06-08-2006, 02:37 PM
I have a 5" Autometer Monster Tach I would sell you if you are interested. It came on the car I just bought, but it's coming off as soon as I get some time. I'd rather have the tach in the cluster.
Old 06-08-2006, 02:58 PM
how much and where do live for shipping
Old 06-08-2006, 06:06 PM
ive done some searching and half of the people are saying they've hooked it without a adapter on the second gen and the other half the opposite
Old 06-08-2006, 09:23 PM
So the only way to find out is to try it
Old 06-08-2006, 10:52 PM
It looks kinda like this one...
http://stores.channeladvisor.com/tir...itemid=3005043
I live in Houston, TX. Say $65 plus shipping and you will need an adapter with the Autometer. Sunpro Powerline model that works without the adaptor.
Old 06-09-2006, 07:02 AM
now that you say that everyone that said they didnt need the adapter said they had a sunpro.
Old 06-09-2006, 02:05 PM
It's the only that I know of that doesn't need the adapter.
Old 06-10-2006, 03:18 AM
maykelcj's Avatar
maykelcj maykelcj is offline
I have that tach on my car and it does need the adapter to run properly. neons tach signal are ~2-3V and most tachs work with a square signal of 12V. the autometer tach is very good and it might work (mine did) without the sift light, yet the only reason to put that monster tach is to have that shift light, so go for the adapter and save time and headaches.
12:1 all motor neon, sold
got me a CRX HF and put a DOHC ZC on it.
