Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars) > Off Topic
Off Topic This forum is for allother discussions
Old 07-25-2006, 03:00 AM
Broke_as_****'s Avatar
Broke_as_**** Broke_as_**** is offline
To quote Socrates: ITS ABOUT BLOODY ****IN TIME!
Yes, ladies and gentlemen and K3, Brokes car is running.
Not only does the engine run, the entire car as a whole is driveable.
I can hear you thinking "Bullshit" as I write this so here it is:
Look at that! It's somewhere OTHER than in the driveway or the garage!
Idles a bit off, still have to check the timing, has a power drain off something (thinking alarm system), needs a good bath and I still have to get it smogged and back on my insurance but shit, its running. And only 25 months and $10,000 over the original budget.
Only real problem is that it seems it will be hard to keep it off the boost for the next few hundred miles. Not so much because of temptation, although there is that, but simply because with all the mods on stock turbos boost starts coming on even at mild throttle very quickly. But it's not like this is a bad problem to have.
Oh and the Borla pipes....oooooooooooooooooooooooh the sound of the Borla pipes. There is a song that embodies sensuality and it is sung on 2 1/2" stainless steel.
1989 240SX Fastback. . . . . . . . . . . . . . . . . . . . . . . . . . . 1995 300ZX Twin Turbo
Warning: Objects in mirror aren't as fast as they thought they were.
Old 07-25-2006, 03:54 AM
Re: To quote Socrates: ITS ABOUT BLOODY ****IN TIME!
Oh yeah:
There it was, the original 18.3 miles I traveled before eating piston. I think I have 28 something on it now.
Old 07-25-2006, 11:19 AM
DeleriousZ's Avatar
DeleriousZ DeleriousZ is offline
Send a message via MSN to DeleriousZ
i'll be damned... well it's good to hear it's running finally.... bit of a difference from the s13 eh
ZedEx Crew Member #6
1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc.
blown turbo, under construction.. gt35 coming.
Old 07-25-2006, 03:25 PM
k3smostwanted's Avatar
k3smostwanted k3smostwanted is offline
Z Cars Fanatic
Send a message via AIM to k3smostwanted
very nicely done...now fix that idle and you will be good to go. just in time for gas prices to jump up again.
man im pissed now...where the f*** is my Z?
ZedEx Crew Member #4
Old 07-25-2006, 11:33 PM
Especially since the 240's head gasket finally gave out after a very long poor running, no leak coolant loss, milky oil, overheating battle. But that should be taken care of in the next week or so and done with. Ready for another 219,000 miles.
Pfft, better to get my car done as soon as possible then, it's not like the prices are going to go down.
That would be back in Illinois, unless you got an Enchanted Suitcase of +2 Holding.
Old 07-26-2006, 04:19 PM
robzone0911 robzone0911 is offline
Hopefully in a couple of weeks I can say the same thing about my car.....still pissed about letting my friend break my car ! Well....that will never happen again
1...2...3...go! 16.3@85mph 2001 Cavalier Z24 Happily traded for my Z32
Old 07-26-2006, 04:28 PM
"Never happen again" like you're not going to let him drive it or "Never happen again" like he's at the bottom of a river somewhere?
Old 07-26-2006, 07:03 PM
-The Stig-'s Avatar
-The Stig- -The Stig- is offline
On Fire!
Send a message via AIM to -The Stig-
Hmm still on stock turbos? Any reason for not upgrading while you rebuilt it?
2003 Chevy 1500HD - Hauler
1971 Chevy Camaro RS - Track Car
User Guidelines It's important to read, like the Bible. But unlike the Bible we will strike you down if you jerk off around here.
Old 07-26-2006, 08:23 PM
Ran out of money, I've essentially been unemployed for the last year. Picking up a truck a few times a month paid the bills and left a bit for the Z but turbos and manifolds would be another ~$2500. Funny thing is that just as I get it back on the road I come across an interesting full time job opportunity. See how the interview goes. If all goes well then I'll probably pull the engine this winter and upgrade then. It's too nice out to have the car sitting.
Old 07-26-2006, 10:28 PM
Z Cars Fanatic
this is so true...and this explains my purchase of a bike.
Old 07-31-2006, 12:02 AM
Well, I was talking about never letting him drive it again, but I think I like your idea better. I am actually alittle over 3/4's of the way finished with the swap. I just need to put the upper plenum back on, hook the harness to the engine, and sort out the spaghetti bowl of vacuum lines. Everything else is ready. (I think)
Old 07-31-2006, 12:24 AM
Doing a EGR delete gets rid of that pair of metal vacuum tubes on the passenger side of the plenum and a few more in the back. Doing a throttle body coolant line delete gets rid of everything under the plenum and only causes three reroutes (and I think only one on a NA car). A PRVR delete doesn't clean up alot but it does get rid of the extra vacuum hoses between the fuel pressure regulator and the plenum. All that really helps clean up the engine bay.
The PRVR lines are a bit different on a NA though so check the manual for that.
Old 07-31-2006, 02:49 PM
Sweet, well I'm not gonna hijack ur thread so....latez
Old 07-31-2006, 03:49 PM
Z Cars Fanatic
Carbon canister delete also can get rid of a few lines running from the front.
dont forget those pesky AIVs. they dont get rid of any vacuum lines but they are useless and usually arent working properly 10-15 years later.
