10 bolts suck!
rear #1 - bearing cap failure, death somewhere between nov and jan 04-05
rear #2 - MASSIVE amounts of metal in it, still not checked out, most likely axle bearing death - removed may 06 rear #3 - Pinion bearing is annihilated, miracle the bearing is still together, this was discovered today My friend (works at his uncle's shop... they're done dozens if not hundreds of rears, custom cars, dragsters, etc) is gonna replace all the bearing for me and check out my Eaton to make sure it's fine and doesn't need a rebuild... best case scenario his uncle lets him do it as a side job, my cost $150 plus parts... second best his uncle doesnt let him do it as a side job, costs me $250-300 (discount from $350) plus parts... worst case scenario the bearing lets go, whoel rear gets F'd from pieces of the bearing flying around in there, will end up costing me around a grand. I should just buy a goddamn 12 bolt already.
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later. 194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies 179.75 RWHP, 204.52 RWTQ ON ITS WAY: MORE R.I.P. Andy 87 Benz 190e - DD 01 EX250 - still gotta get my license for this thing |
Firebird Guy
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2004
Re: 10 bolts suck!
Yes you should.
![]() Somehow my 10 bolt is still in one piece.
1999 Pontiac Trans Am WS.6 #1747 Stock'ish' |
#3 | ||
Is eating.
Re: 10 bolts suck!
Has a Camaro
Re: 10 bolts suck!
build a 12 bolt, there strong as hell, a ford 9" is stronger but you dont want to put a ford rearend in a chevy, thats a sin. im also suprised that l mr. luos' rear end hasnt self destructed yet
Formerly Blownalcoholboy 1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi) Best ET 1/4: 8.35 @ 170mph (275 drag radial) Best ET 1/8: 5.44 @ 132mph (275 drag radial) Best 60': 1.31 on the back tires (275 drag radial) AF User Rules/Guidelines http://www.automotiveforums.com/vbul...uidelines.html |
Firebird Guy
Re: 10 bolts suck!
Hasn't hooked.
Fight the powwa!!!
Re: 10 bolts suck!
When Mr.Luos's finally hooks well at the track his rear will start spitting teeth like a Senior Citizen bar fight.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart. Mods: Weight reduction (I don't wear underwear) |
#7 | ||
Fight the powwa!!!
Re: 10 bolts suck!
#8 | ||
![]() Join Date: Jun 2004
Re: 10 bolts suck!
But ya'll have to remember, when the 10bolt was designed, the tires they had then couldn't hook for shit. |
#9 | |
![]() Join Date: Aug 2005
Re: 10 bolts suck!
i am getting ready to put a 3.73 posi unit in my 10 bolt on my 92 camaro. Maybe i will just build a 12 bolt instead.
95 Z71 Silverado 4x4 ext. cab Mods- Flowmaster Exhaust,Intake |
#10 | |
Son of Satan
![]() Join Date: Feb 2005
Re: 10 bolts suck!
My little 3.8 has almost destroyed the gears in the stock 10 bolt, I could only imagine making huge amounts of power.
#11 | |
Cheesesteakoholic
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2004
Re: 10 bolts suck!
Don't know... I've got a 10 bolt, hooks up almost immediately, and haven't had a problem with it yet. Can't say the same for everything else, but the 10 bolt is good.
#12 | |
Fight the powwa!!!
Re: 10 bolts suck!
He is referring to the 7.5/7.625 10 bolt. The 8.5 10 bolt that was used in the second gens is much stronger.
#13 | |
Cheesesteakoholic
Re: 10 bolts suck!
I see... I would think that you could pick up a 2gen rear for almost nothing... especially the 74-77 years. They should be direct swap shouldn't they? Or is the rear suspension different on 3 & 4 gens from 1 & 2 gens? Did they use leaf springs on 3/4 gens? Even if not, you can modify the housing to accept the new suspension can't you... the rear itself is the same right?
#14 | ||
Fight the powwa!!!
Re: 10 bolts suck!
