reset air bag light
hi!
does anybody knows how to reset the air bag light? mine came on, went off, came on again and stayed on since, (almost a month) any ideas? thanks. louie
Re: reset air bag light
you need to access the air bag module with the proper scanner to turn the light off.
http://www.indyspeedandchrome.com |
not sure if you're still trying to do this but if you are you need to find out what the codes are then repair the problem then u can undo batt and the light will stay off if problem fixed. If you don't have a way to check codes normally sedonas have a tendancy to brake driver's and passenger's (front) seat belt buckles if you inspect the whole wire you will see is cut if this is your problem hope it helps
