Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Silverado
Old 05-17-2006, 07:47 AM
Silverado514's Avatar
Silverado514 Silverado514 is offline
What is the best setting for 2003 5.3L
What is the best setting for 2003 5.3L from the Hypertech Power Programmer?
this car has only Gibson Exhaust - Super Truck
?? OCTANE
?? RPM
?? MPH
?-? Shift Point + ? RPM
Shift Firmness %?
Thanks All
2003 Silverado 1500 LT
Gibson Super Truck Exhaust
Old 05-17-2006, 12:36 PM
Re: What is the best setting for 2003 5.3L
?? OCTANE
?? RPM
?? MPH
Shift Firmness %?
Thanks All
Guys any HELP
Old 05-17-2006, 01:05 PM
silveradoHO silveradoHO is offline
93 octane
5900 Rev limit
Top speed H 128mph
shift points 1-2 +1mph
2-3 +8mph
3-4 +5mph
Shift Firmness-On
Old 05-17-2006, 01:13 PM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
There is a sticky thread here in the forum you might want to take a look at. In al lseriousness, if you want the best performance, get rid of the Hypertech and get a custom tune from Nelson.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 05-17-2006, 03:07 PM
Originally Posted by silveradoHO
93 octane
5900 Rev limit
Top speed H 128mph
2-3 +8mph
3-4 +5mph
Shift Firmness-On
Too much for a truck with only a cat-back Gibson Exhaust - Super Truck
also the shift points should be RPM not MPH and the Shift Firmness (25% to 100%)
I tried it today with:
5400 Rev limit
Top speed H 128mph
shift points stock
Shift Firmness 25%
was Ok but it cut-off in the first gear when reash the 5400RPM
Thanks guy for your replies
Old 05-17-2006, 08:42 PM
Moze's Avatar
Moze Moze is offline
Yeah I was going to say the best setting woud be setting it back down on the shelf at AutoZone and springing for the Nelson Tune - you won't be sorry you did. He can do things HyperTech can't touch.
2003 SILVERADO Z71 ECSB 5.3L - NELSON TUNED - YANK 2600 CONVERTER - DOUG THORLEY TRI-Y HEADERS - SPIN TECH MUFFLER - 224/224 .563/.563 112LSA CAM - TRUE FLOW AIR INTAKE SYSTEM - PORTED THROTTLE BODY - THROTTLE BODY BYPASS - LS1 ELECTRIC FANS - NELSON FAN HARNESS - 160° T-STAT - WALBRO FUEL PUMP - AMSOIL SYNTHETIC OIL - WWW.LS1TRUCK.COM
Old 05-18-2006, 01:26 AM
I wish I could tune it by Nelson but unfortunately I'm outside the US continent.
So I only get the stuff from the Internet.
Thanking you for the help again
Old 05-18-2006, 01:39 PM
jeverett's Avatar
try a wait4me tune
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 05-19-2006, 07:52 PM
Rammer500 Rammer500 is offline
Why do you have a 5400 rev limit? Factory is 5900. I have mine tuned for 6100. My 1-2 is at 5800, 2-3 at 5600.
Old 05-22-2006, 07:40 AM
jeverett's Avatar
Be careful if you're setting the rev limiter higher then 5900. I had my shift points and rev limiter set all f'ed up and I over-revved my engine.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 05-24-2006, 12:17 AM
This what I received from the techsupport@hypertech
The only option that increases power is choosing Yes to our Power Tuning for 87 or 93 octane fuels. The 93 setting is the most aggressive and there must be 93 octane in the tank. The shift point adjustments only affect wide open throttle shifts. +3 on the 1-2 shift and +6 on the 2-3 shift are good starting points. At wide open throttle on the 3-4 shift you are traveling at a high rate of speed and most never see the 3-4 shift at WOT. You can go as high as +8-9 on the 3-4 shift if you like. Be sure to move the rev limiter up to at least 6100 rpm to get it out of the way. It will shift before hitting the rev limiter with these settings.
Thanks All
Old 05-25-2006, 04:14 PM
Thanks All
That's about what I told you. I have a hypertech for my 2005 and the settings I suggested work great. Why did you say the shift points should be by RPM's if Hypertech goes by mph? I don't know if yours if different, but mine only had the option of shift firmness on or off, it didn't give percentages.
Old 05-26-2006, 05:12 AM
maybe my Hypertech is an old version becouse it gave me the shift points by RPM's and the shift firmness by percentages.
I don't know if there is anyone alse have the same problem?
