Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 05-25-2006, 03:07 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
We have: fuel, compression, timing, and spark. We dont have a running car. HELP!
So like the title says, Mike's 1991 Talon has spark, gas, compression (135 across), and perfect timing but it wont start. It will fire a few times and die. I am out of ideas. Mike is calling a local DSMer to see if he has an extra ECU (he does) and we're going to try that. Other than that, I'm lost. Any other ideas?
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 05-25-2006, 03:46 PM
MexRocket's Avatar
MexRocket MexRocket is offline
Re: We have: fuel, compression, timing, and spark. We dont have a running car. HELP!
http://www.automotiveforums.com/vbul...d.php?t=536256 I knew you already posted this exact thing =P
EDIT: it cranks over or what? It could be one huge boost leak..... I would do a boost leak test.... i know it sound way off but wouldnt hurt
STATUS: Near completion for the Engine
PROJECT BEST 1G IN IL:70% Done
MODS: C2 boost,mbc,B16GEGTurbo,12x28x3x3 FMIC,Ported2gmani,k&n.
Being bought in two weeks: Dsmlink,880's,3"exhaust,piping,suspension,axel,dri lled and slotted brakes.
Old 05-25-2006, 04:36 PM
wanaplay134 wanaplay134 is offline
Send a message via AIM to wanaplay134
yea im having the same problem and i just opened my ecu and the thing looked like it was on fire at some point
1992 eagle talon tsi awd
xtd stage 3 six puck/apexi 3' downpipe and exhaust/ngk plugs/taylor thunderbolt wires/manual boost controller set at 20psi/walbro 255 with rewire/autometer boost gauge/turbo xs rfl blow off valve/arp headstuds/ to4b vtrim turbo/dnp tubular manifold with o2 housing and tial 38mm wastegate/eagle rods/ross pistons/acl bearings/arp rod bolts/arp main studs/aeromotive fuel pressure regulator and all stainless lines/aem fuel rail/slowboy street front mount kit
Old 05-25-2006, 07:46 PM
Thor06's Avatar
Jizzed In My Pants
Holy hell, I do not remember posting that, however I remember reading that the 90 and 91 ECU's were different. Fuck me (sorry mods).
Good call on the boost leak, one thing I forgot to check was if the IC pipes. Wouldnt that be a bitch, find out that all along its been a half on LICP or something.
Mike got that ECU and tried it, no difference. He got it to run for like 3 seconds and then it died.
So as I read in my other post, the EGR could be causing it to not run? How would I go about cleaning the injectors? I dont think its the CAS, correct me if I am wrong, but the fuel pump wouldnt turn on unless it got signal from the CAS and we do have fuel (sprayed in my fave when we were checking for spark). Any other ideas?
Old 05-25-2006, 09:41 PM
MexRocket's Avatar
Well IM going with a boost leak, because EZ's car did the same thing, with tons and tons of leaks from the head to the smim.
Old 05-26-2006, 12:23 AM
steviek's Avatar
steviek steviek is offline
do you have a boost gauge on that car because, My car Idles at 18-20hg if its showing anything lower I would definately start testing for leaks.
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 05-26-2006, 12:25 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
I would test for leaks regardless of what a gauge says. A boost test is a simple and effective way to narrow down alot of symptoms.
95 Talon TSI AWD
97 Eclipse GST
Old 05-26-2006, 12:27 AM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Usually the boost gauge only works while the car is running
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 05-26-2006, 12:32 AM
Haha I agree, it'd be kind of hard to get a reading at idle......IF THE CAR DOESN'T EVEN RUN!!!!
95 Talon TSI AWD
97 Eclipse GST
Old 05-26-2006, 12:36 AM
raymonator raymonator is offline
Send a message via Yahoo to raymonator
Do you have injector pulse ????
Old 05-26-2006, 03:31 AM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Coil Pack?
1991 GSX 2.3 Stroker
Old 05-26-2006, 06:08 AM
steviek's Avatar
he siad he gets 3 seconds thats enough
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 05-26-2006, 04:18 PM
Thor06's Avatar
Jizzed In My Pants
Well, seeing as how air/fuel mixture shoots into my face witht the spark plugs out and all the plugs are gapped right and sparking, I dont think the coil pack or injectors are having problems. One of our other friends put the LICP on, I bet its not even all the way on. Mike is going to check when he gets home.
