Go Back   Automotive Forums Car Chat > Oldsmobile > Intrigue
Old 04-26-2006, 12:59 PM
philburn philburn is offline
Sticky Gas Pedal
My '01 has a sticky gas pedal when I start off. After the initial acceleration, the stickiness goes away. It's almost as if the pedal is stuck until I have to put so much pressure that the car jumps forward (or backward for that matter).
Thanks
Old 04-26-2006, 02:08 PM
dtownfb dtownfb is offline
Re: Sticky Gas Pedal
My first instinct is you should clean out the throttle body. Very easy. Sits down stream of the air filter and mass flow filter. They sell cleaner for about $3 a can. Will take you about 15 minutes from start to finish.
Old 04-26-2006, 08:08 PM
canatto canatto is offline
I second.
When I was at it I had my son floor the gas peddal so that I could clean the back side of the valve plate as well-- lots of junk there too.
The throttle response became so much smoother.
