Go Back   Automotive Forums Car Chat > Honda > Integra
Old 04-05-2006, 01:32 AM
SCOOBY37151 SCOOBY37151 is offline
Starting Problem
I Have A 91 Acura Integra When I Turn The Key The Starter Motor Dosen't Turn. Replaced The Starter Motor And The Ignition Coil Same Problem. Checked The Starter Relay It Checked Out Ok. What Else Should I Check? CHECKED ALL FUSES(ECU,.ETC).
Old 04-10-2006, 07:55 PM
whitGSR07 whitGSR07 is offline
Re: Starting Problem
neutral/safety switch....connection from positive post to starter...starter ground. Don't know what 91 integra has but...camshaft pos. sensor or crank pos. sensor.
Old 04-20-2006, 09:18 AM
clampjockey clampjockey is offline
check your body grounds. hope it helps. gl.
Old 04-20-2006, 09:19 AM
oops, sorry, I see whitgsr07, already said to do that (starter ground). my bad.
