Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 04-18-2006, 07:22 AM
siklein siklein is offline
Angry radiator losing fluid 92 camry
My 1992 camry, every 3 days or so I have to ad radiator fluid (about 1/2 galon or so), however car does not overheat, but temp gauge goes to red zone I changed the hoses, and the radiator and the cap, but problem has not been solved. I do not see any leak under the car either? Any suggestions?
Thanks
Old 04-18-2006, 08:02 AM
GSS123 GSS123 is offline
Re: radiator losing fluid 92 camry
I would check your engine oil and make sure the fuild is not showing up in your oil pan. Next I would recommend you have a local service station but a pressure test on your radiator and see if they can spot the leak. If not then ask them to add some dye to the radiartor fluid and drive your car for a few days. The dye will seep out and show up with use of a black light.
One more thing check your floor boards and see if the carpet is moist. You may have a heater core leak?
Old 04-18-2006, 10:03 AM
popeye08 popeye08 is offline
Also check the water pump.
