| Off-Topic Talk about anything other than cars. |
1990 Eclipse GST HELP!
I am having an issue with my eclipse... I change the battery today, and I had the distibuter replaced... but I am still not getting a spark to the engine... Could you all be so kind as to give me a troubleshooting list so that I may get this car on the road again... Thanks... I normally can figure out what the issue is... But I have gone thtough some things and so has 2 of my other buddies, and we are all scratching our heads on this!
Re: 1990 Eclipse GST HELP!
Problem #1 our cars don't have distributors, if you put one in that is why you aren't getting any spark. :P
Check ll the connections on the COILS and then check the cas and ecu.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff. http://www.ratemydsm.com/member/ez1286/?member=ez1286
It wasnt then distributor... It was the coil, all the spark plug cables, spark plugs, I finally realised that I wasnt getting spark from the source, so it didnt matter... But my buddies have beeen working on it since yesterday, and they dont know what else to do... This is my 2nd GST, and never had this problem with it...
My last one had a DET Red top 4g63, and I want to do something to this one... of course I would have to get it on the road again. I will check out those others tho thanks |
You could have them check the Cam Position Sensor. When I had mine it had sort of the same problem, it was only firing on 2 cylinders. But then it ran fine when I replaced it.
1969 Olds Cutlass 1985 Olds Cutlass 2000 Ford Ranger 2001 Jeep Cherokee Sport |
