Go Back   Automotive Forums .com Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 04-07-2006, 11:28 AM   #1
2000mudder
2000mudder's Avatar
front axle vacuum motor
dose anyone know where i can get a cheaper vacuum motor that engauges the front axle? they want $140 everywhere. or is there a manual engauge kit anywhere? it's a 91 w150. the axles are the same up to 2000 as far as i know.
2000mudder is offline   Reply With Quote
Old 04-09-2006, 04:26 PM   #2
Stevo2
Stevo2's Avatar
Re: front axle vacuum motor
You can lock it permanenetly but need hubs.
http://ramchargercentral.com/boards/...?topic=59727.0
You can get a Posi Lok setup but....$$$
http://www.4x4posi-lok.com
You can try www.makeitmopar.com online for a cheaper OEM part? $$$
You can try the junkyard but how long will it work?
The vacuum motors are different from 94 on up.
Jack of all trades...Master of none!
Could someone please fix my Instant Email Notification?
Please get back to us with your fix!
Why did you buy a $40K vehicle and not a $100 Factory Service Manual?
Stevo2 is offline   Reply With Quote
Old 04-10-2006, 02:17 AM   #3
2000mudder
2000mudder's Avatar
tks for the info.all sites i found want $140 for the vacuum motor and the manual lock is $190. i geuss i'm just gonna live with 3 wheel drive for now. maybe tractor supply home made one down the road!!!!
Old 04-11-2006, 12:52 PM   #4
horse482
AF -Advisor
horse482's Avatar
check this out, it may work better for you. http://www.4x4posi-lok.com/app_dodge.html
NO 4 N JUNK
1994 GMC K1500 XC 5.7L
2008 Chevy Impala LTZ
horse482 is offline   Reply With Quote
Old 04-11-2006, 02:12 PM   #5
scoutinkeith
scoutinkeith's Avatar
Send a message via AIM to scoutinkeith
not to burst your bubble or anything, but with a disconnect type axle, if the disconnect is not engaging, you'll only have two wheel drive, even if the T-case is in 4x4. all that torque that would normally go to the front wheels is going to go through the differentail, and to the intermediate(sp) shaft, and none of it will get to the wheels. the only case where this would not be true is if you have a locker or spool in the front.
as far as fixing your disconnect problem, you can make your own "posi-lock" type device relatively cheeply. depending on how fancy you want to get, you should be able to get the parts for anywhere from $10-$50.
basically you need to get a push/pull locking cable, and a way to attatch it to the shift fork inside the actuator housing.
when all else fails, get a bigger hammer.
Vehicles:
2005 suburban 1500 4x4
all stock, ex-fire department truck.
1987 Grand Wagoneer
scoutinkeith is offline   Reply With Quote
Old 04-11-2006, 02:53 PM   #6
scoutinkeith
here ya go, I searched a little and found this, it's how to convert your vacume actuator to a manual one, similar to the posilock, but the guy that did this only spend $20!!!
http://home.earthlink.net/~stevenschreiber/cabledis.htm
Vehicles:
1987 Grand Wagoneer
Old 04-12-2006, 04:38 AM   #7
2000mudder
2000mudder's Avatar
thanks scoutinkieth!!! thats exactly what i was lookin for. actually on dodge fronts (dana 44) axle, the right side is permantly connected to the diff and driveshaft so i would have one front tire driving. the shift fork just engauges the left side split shaft together to make it posi traction.
Old 04-12-2006, 08:09 AM   #8
scoutinkeith
so is your front differentail locked? if not, even though one side is still connected to the dif by the one piece axle shaft, it won't get any power. simply put, an open differentail will send power to the tire with the least amount of resistance.
to better demonstrate this, crawl under the truck and spin the front drive shaft. with the front axle disconnect disconnected, it's like having one tire off of the ground, and with an open differentail, the power is sent to the side with the least amount of resistance, which in this case would be the intermediate shaft between the dif and disconnect.
I'll do some more looking to see if I can find some more information to explain this a little better.
Vehicles:
1987 Grand Wagoneer
