Go Back   Automotive Forums .com Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 04-12-2006, 09:45 PM   #1
Bob Bauman
Bob Bauman's Avatar
90 ram i need wire diagram for cruise control
Ok i'v changed every thing under the hood but no cruise control yet what all is left ?
Bob Bauman is offline   Reply With Quote
Old 04-13-2006, 01:29 AM   #2
Stevo2
Stevo2's Avatar
Re: 90 ram i need wire diagram for cruise control
Have you checked continuity of the switch on the steering column?
Fuses, stop lamp switch?
1.Disconnect the blade type four wire electrical connector from base of steering column.
2.Using a continuity tester, or an ohmmeter, check for continuity at connector wires. Do not use a test light.
3.Results should be obtained according to the charts. If these results are not obtained, replace switch.
Jack of all trades...Master of none!
Could someone please fix my Instant Email Notification?
Please get back to us with your fix!
Why did you buy a $40K vehicle and not a $100 Factory Service Manual?
Stevo2 is offline   Reply With Quote
