Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 04-05-2006, 06:24 PM
trigga_b trigga_b is offline
RPM drops to almost 0 then goes back up
RPM drops to almost 0 then goes back up, this happens when i shift from r to p or p to r
Old 04-06-2006, 05:16 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: RPM drops to almost 0 then goes back up
It sounds like a crank position sensor going bad, but it could also be a bad motor mount allowing the engine to move around too much and pulling on the crank sensor wires causing the rpm drop.
Old 04-07-2006, 09:16 AM
sixsmiles sixsmiles is offline
Question Re: RPM drops to almost 0 then goes back up
I think the Crank Position sensor is the best suggestion, but I had a bad engine to H Frame ground that caused this kind of problem. I ran a new 18 gage wire from a bolt on the engine to the h frame and it solved all problems.
