Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 04-11-2006, 02:30 PM
fender5's Avatar
fender5 fender5 is offline
Send a message via AIM to fender5
Fuel Filter Question
So, decided that its time to change the fuel filter for the first time. I read the chiltons guide to doing it and it wants me to do all sorts of crazy crap (drain the fuel, take out the whole fuel tank) so i was wondering if anybody has any advice as to what i really need to do so i dont have to take 5 hours changing this damn thing. BTW its a 92 (1g) 1.8L N/T Thanks
Old 04-11-2006, 03:31 PM
Killa's Avatar
Killa Killa is offline
Re: Fuel Filter Question
I dont know how to change on 1g ( I do own one now and need to change fuel filter soon ), on my 2g, all I do is take out the old filter ( the filter is locate under rear passenger seat ) and put the new one back in, no need to take out fuel tanks, just find where the old filter is and take that out and replace with the new one, that all.
GM FOR LIFE !!
NEW 1997 Camaro z28 6 speed
illa never going back to import , but killa alway be nice to any DSM he saw
looking for 2002 Trans Am LSX
UPGRATE 2010 !! 97 Camaro Z28
95 camaro lt1
1992 Pontiac Firebird v6 auto -sold -
Pony 1998 Mustang GT 4.6L Manual. Black
1995 Eagle Talon TSI AWD Turbo manual R.I.P
1994 Mitsubishi Eclipse Manual gray -Sold
1997 Mitsubishi Eclipse RS Auto White - Sold
Old 04-11-2006, 04:31 PM
fender5's Avatar
Ok so now that i found the fuel filter (firewall) i cant get the damn bolt off. I can really heat it up unless i want to have a gasoline fire so any other ideas for getting a frozen nut off? The filter housing cannot be removed because there is the hard line running to the gas tank. So anybody have any special miracle creams or techniques?
Old 04-11-2006, 04:34 PM
antwn_5k's Avatar
antwn_5k antwn_5k is offline
alot of cars have 2 fuel filters, and having one inside the gas tank can be common but rarely do people change that one as part of routine maintnance. Usually the more visible one is changed.
Old 04-11-2006, 05:49 PM
ned032002's Avatar
ned032002 ned032002 is offline
Have you removed the battery and battery tray? If not then do so cause it helps tremendously, then try some pb blaster on it that should help. But I found that when I changed mine I used to wrenches (one on the top and the other on the bottom) at the same time to get the filter off.
Old 04-11-2006, 06:38 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
I changed mine in like 10 minutes... You can't just loosen the one nut. You need two wrenches to turn both nuts side by side and it will be tight as hell but you just gotta muscle it... Only other thing I can think of that may help is to spray it down with penetrating oil and let it set overnight with it on there. I usually spray down suspension parts with pb blaster (penetrating oil) and let them soak overnight before I even touch em and it usually helps a lot. Another thing I will warn you about now is that your gonna have all the fuel drain out of the fuel rail when you take that line off. It may take a few extra cranks to start it up again after your all done. Oh, and crank down those fuel filter nuts before you start it or it'll spray fuel everywhere.
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 04-11-2006, 07:19 PM
Eagalicious's Avatar
Eagalicious Eagalicious is offline
fOR JUST $19.95.. yes that's RIGHT!!! Just $19.95 plus expenses to your local, I can use me old Jedi Mind Trick.
Have you tried any products like WD 40 and let it soak in to break it loose? All that I can think of. Good luck dude and becareful.
John
Eagalicious's
1997 Eagle Talon Tsi AWD
K&N FIPK
3rd gen lifters, installed
Apexi Turbo Timer w/harness!!! now to install
Eibach Springs coming soon
3" turbo back with straight pipe.
The muffler was the wrong one
Manual BC
1G BoV
The rest is stock but not for LONG!!
Old 04-11-2006, 07:23 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
I think you need a flare-nut wrench for the bottom nut i think it's 17mm maybe 19mm. Be sure to use a flare-nut though or else you could be in trouble.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 04-11-2006, 07:36 PM
fender5's Avatar
I let the top nut soak in WD-40 for a while and it was still pretty tough but i got it out. The bottom flare nut on the other hand, well thats another story. I took out the battery and the tray and the air filter hose but its hard to get into that flare because of the hard line coming in. But ya, what a pain in the ass, im pretty sure thats its never been changed since the production line in 92'. So Eagalicious, if you want to send some of that jedi power my way i'd appreciate it!!
