Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 03-26-2006, 03:23 PM
mrazekt2002 mrazekt2002 is offline
Testing a speed sensor
I have a 1993 chevy G20 van and the speedometer quit working and the trans wont shift out of first after I changed the battery, spark plugs, and air filter. Someone told me to check the speed sensor, so i replaced the speed sensor and it didn't fix the problem. Is there a way to test the speed sensor or the connection. Please let me know as soon as possible. Thank you.
2004 Grand Prix GTP Comp G
1996 Volkswagen Passat GLS
Old 03-27-2006, 02:51 AM
Blue Bowtie's Avatar
Registered Offender
Re: Testing a speed sensor
Most of the later VSS are optical, not magnetic. The only reliable way to test is with either a datalogging scanner or a logic probe at the wire harness.
Old 03-28-2006, 12:19 AM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
in your 93 you can check it with a dmm and check the ohm rating on all vss, if one is out in left feild, its bad, i beleve 15k to 20k ohms is exceptable
