Go Back   Automotive Forums Car Chat > Dodge > Caravan | Voyager
Old 03-29-2006, 08:49 PM
pastor_dave pastor_dave is offline
Question need help changing front disc brakes 1988 GV
i need help changing front disc brakes on a 1988 GV
i can not remove brake pads when the caliper is unbolted
from the car - how do they come out????
thanx for any thoughts
Old 03-30-2006, 12:18 AM
KManiac's Avatar
KManiac KManiac is offline
Re: need help changing front disc brakes 1988 GV
Evening, Reverend:
My Chilton Manual for 1984-1994 Caravan/Voyager states the following after removing the caliper from the disc:
Pry the outboard pad toward the bottom opened end of the caliper. The pad is retained by a captured clip. Remove the pad. (The illistration shows a screwdriver inserted between the bottom of the horseshoe shaped opening on the end of the caliper and the top of the pad.)
Remove the inboard pad by pulling it outward from the caliper piston. It is retained by a captive clip. (The illistration shows hands pulling the pad away from the piston, toward the opposite end of the caliper.)
I hope this helps. Let us know what you do and what you find.
"This car may be old, but it will still climb Kirker Pass at 110!"
1962 Chrysler 300 2-door hardtop/1964 Chrysler 300-K convertible/1964 Chrysler Newport 4-door sedan/1964 Chrysler 300-K hardtop with Firepower 390/2x1964 Chrysler 300-K hardtop/1964 Chrysler 300 convertible/1964 Chrysler "Silver 300-K" with factory 4-speed/1964 Chrysler New Yorker Salon/1980 Dodge D-50 Sport/1986 Lincoln Continental/1989 Honda Accord DX/1989 Lincoln Mark VII BB/1991 Dodge Shadow ES convertible
Old 03-30-2006, 05:22 AM
Stevo2's Avatar
Stevo2 Stevo2 is offline
http://autozone.com/servlet/UiBroker...3d801293e0.jsp
Jack of all trades...Master of none!
Could someone please fix my Instant Email Notification?
Please get back to us with your fix!
Why did you buy a $40K vehicle and not a $100 Factory Service Manual?
Old 03-30-2006, 07:04 AM
Arrow Re: need help changing front disc brakes 1988 GV
thanx for all your help for us mechanically challenged
the calliper guide pin is the obsticle - rounded flats
will make removal more difficult but NOT impossible
thanx again
<david><
