Go Back   Automotive Forums Car Chat > Ford > Commercial Trucks
Old 03-05-2006, 08:51 AM
circleScrane circleScrane is offline
L8000 Help This truck is killing ME!!!
The truck is a 94 Ford L8000 with a 8.3 liter motor and a Eaton 8 speed.
The Problem is the truck runs fine until I put it in 7th and 8th gear. Its like its not getting fuel. The turbo will wine down and there is a complete lose of power. If I push in the clutch the motor will wined back up and then lose power after letting the clutch back out.
I have replaced all rubber fuel line, lift pump, and fuel filter and number of times.
I'm going to check the turbo today to make sure it looks ok.
I'm at the end of my rope and any help would be highly appreciated.
MIKE 832-347-8703
Old 03-31-2006, 08:09 PM
picuduke picuduke is offline
Re: L8000 Help This truck is killing ME!!!
had the same problem. there is a very fine screen before the fuel filter clean that. mine was all sludged up. its before the filter. also put fuel additive in it. and ford with all there infinite wisdom put a decal in the botton of the fuel tank and the fuel loosend it up and plug everything up. good luck
Old 04-06-2006, 10:18 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Check the fuel pick up tube in the tank. Some @sshole vandal put a plastic shopping bag in the tank of my L9000. It got sucked into the fuel pick up tube and partially blocked it.
