Go Back   Automotive Forums .com Car Chat > Cadillac > Eldorado
Old 01-20-2004, 02:02 PM   #1
worthylake
Question ignition module
I have a 1983 S series jimmy , I took out the 2.8 and 5spd and stuffed in a 350/700r4 4X4.
I have two problems , my first is the ignition module , the dist is a out of the box malloroy HEI unit ( stand alone )when it was first installed , the truck ran great , snappy response , but that gradually went away , the truck became harder to start , faulty module . Replaced it , with supplied heat transfer grease , and everything is back to normal .
A month goes by and then you can feel the performance is off , the truck is hard to start.
I have tried . New O rated resistance 9ml plug wires
. A/C delco plugs gapped @0.40
. Plumbed in a 4" duct from the air dam up to the engine compartment ( thought maybe excessive heat )
. Tried various ign.modules , all lasting and acting the same
. Truck origanally came with an HEI system so Resistor should not be an issue.
Maybe some one out there has experienced the same
worthylake is offline   Reply With Quote
Old 01-25-2004, 12:36 PM   #2
michelq
Re: ignition module
every time ign madule need to be replaced replace pick up coil too with ACDELCO parts
michelq is offline   Reply With Quote
