Old 03-03-2006, 08:29 AM   #1
Mirock
dissapearing coolant. Help please
I'm an owner of 99 rodeo ls 4 wd 3.2 dohc almost 90k on it ,here is a problem.About 4 months ago chenge a timing belt and water pump and since then i'm notticing a lose of coolant ( went low twice already luckilly didn't overheat) .I did crawl under the truck numerous times and check top af the motor ,i can't find anything leaking or smell an antifreeze ,it is a mystery to me where the coolant goes ? Could it be a head gasket leaking? but on the other hand there is no coolant in oil or vice -versa ,cooling system is not getting pressurized like it usually happening with bad head gasket .Did anyone here experienced the same problem? .Can you help me guys.
99' rodeo 4X4 LS
99' mazda 626 wife's toy
Mirock is offline   Reply With Quote
Old 03-03-2006, 11:49 AM   #2
rodeo02
Re: dissapearing coolant. Help please
Pull the spark plugs to check for coolant in the plug wells. That's a sure way to check for a head/gasket leak on the 3.2/3.5's. Unfortunately 1998/1999's were prone to head cracks & coolant leakage into the combustion chamber.
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
rodeo02 is offline   Reply With Quote
Old 03-03-2006, 04:40 PM   #3
directory
directory's Avatar
i hate when you bring that up
i'm sure glad i have a 99 honda passport...
99 passport 3.2L v6 DOHC auto-trans 4x4 modified IFS 10 bolt front/ dana 44 4.10 rear
SKYWARN
we be clubbin'
--B
directory is offline   Reply With Quote
Old 03-06-2006, 04:29 PM   #4
99zhfkaf
i am having the same issue w/my 99 passport. i thought it was a radiator, had it replaced and a month later i was low again. no idea where the coolant goes, no drips or smells. my mechanic claims all tests say head and block are fine. no white smoke out of the tailpipe either. he thinks it's a small leak near the thermostat, in an area covered by the intake plenum(sp?), engine cover and pretty much everything on the top of the motor. let me know if you find anything out. right now i am just checking my coolant level every 2-3 weeks and topping off as necessary.
99zhfkaf is offline   Reply With Quote
Old 03-06-2006, 07:09 PM   #5
Gizmo42
Gizmo42's Avatar
An easy way to tell if coolant is getting into the oil is to pull the dip stick out and taste the oil (just taste a drop, dont drink it).
Even a little bit of coolant in the oil will make it taste sweet. It wont hurt you, I have been doing it for years. It also gives you a reason to have an adult beverage afterwards to get rid of the oil taste.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 2.25" 50 Series
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Gizmo42 is offline   Reply With Quote
Old 03-06-2006, 07:24 PM   #6
sandyf43935
Ewwww.
That's all. Ewwww.
sandyf43935 is offline   Reply With Quote
Old 03-06-2006, 08:49 PM   #7
rodeo02
Originally Posted by Gizmo42
..pull the dip stick out and taste the oil (just taste a drop, dont drink it)..
Gizmo, yer killin' me !
Joel
Old 03-07-2006, 06:06 PM   #8
surferfletch
Did they pressure test it?
surferfletch is offline   Reply With Quote
