Old 02-21-2006, 12:49 AM
ViperJ's Avatar
ViperJ ViperJ is offline
Send a message via MSN to ViperJ
Throttle Body ?'s
I am going to be reaplacing a lot of the intake part of my car in the next month or so and had a question on throttle bodies. What would be better for my car a 52 or 58mm throttle body. My mods are in my sig and I plan on adding a Moroso CAI, Granatelli MAF sensor, Trick Flow Elbow and then the throttle body. As for future plans I am undecide on the big 3, LT4, Nitrous or Supercharger, my goal is mid 12's once done.
White 07 STI, Bone stock for now
Old 02-21-2006, 01:05 AM
drvngstorm05's Avatar
drvngstorm05 drvngstorm05 is offline
Re: Throttle Body ?'s
i got a 54mm throttle body off of ebay, its a stock tb ported out to that size... it looks stock to anyone that would look under your hood, and it costs about 200, plus you get a 40 dollar refund if you send him your throttle body for him to port
'92 RS lt1/t56, lt4 hot cam, 30lb injectors, 54mm throttle body, full exhaust, 4.11 posi, 4 coil ignition, alluminum driveshaft, adj rear suspension, low. springs, electric water pump, custom tune.
Old 02-21-2006, 02:27 AM
Morley Morley is offline
You don't have enough mods to warrant a larger throttlebody. Bigger cam, better heads, etc..then think about a larger throttlebody.
Old 02-21-2006, 10:51 AM
ViperJ's Avatar
Thanks guys, the 52mm one is like $325 from Summit so ill check out ebay. Also if i get the bigger one will that just make my car run really rich because I am not decide on what I will do after these mods.
Old 02-21-2006, 01:32 PM
tcfco2005 tcfco2005 is offline
like morley said...i dont think you need a larger tb yet...your stock one should be enough until you start reaching 400hp or so...
1991 RS
305 T.B.I.
700-R4
Old 02-21-2006, 02:35 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
I hear alot of people tell people that they don't need a larger TB and this may be true however. I have also seen stock LT1's (for the most part stock) gain between 5 - 10 horse from adding a 52MM TB. So I say get yourself a 52MM but I have also seen LT1's lose 10 horse from getting a 58MM. So I say get a 52MM. Also buy a ported stock one. That guy that ports them on ebay has quite a deal its comes out to be like 120 after you send in your old one and alot of the aftermarket one's leak. Dave and I both bought from the ebay guy and have had no problems from mine.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
