Go Back   Automotive Forums Car Chat > Isuzu > Impulse
Old 04-15-2002, 03:44 PM
EvilPixie EvilPixie is offline
Send a message via AIM to EvilPixie
Impulse engine in a geo storm?
I was told that an impulse engine would fit into a geo storm... just curious if it was true.
Old 06-05-2002, 09:01 PM
pist pist is offline
Send a message via AIM to pist
its the same car as far as i know so the answer is probably
Old 08-02-2002, 06:23 AM
90StormGSI 90StormGSI is offline
here is your answer evilpixie
I know quiet a bit about storms...I have a 1990 Geo Storm GSI, ok..
To begin, do you have a (90-93 base model) 1.6 L SOHC, (90-91 GSI models) 1.6L DOHC, or (92-93 GSI models)1.8L DOHC...
If you are looking for turboing, the SOHC you will need to use i beleive it is a 90-up Isuzu I-Mark RS, it has the same SOHC motor but turbo charged...you can turbo you base model motor at low boost or you can swap motors so you can run higher boost but will require alot more work including the ecu and wiring harness....
If you have a 1.6 DOHC you can just use the 90-93 (i beleive those are the correct years) Isuzu Impulse RS turbo AWD, has the exact same motor but lower compression to compinsate the boost....Agian you can use all the turbo parts and exhaust manifold, etc. with a low boost or swap motors for high boost, but more work is included, ecu and wiring harness, etc...
The 1.8 DOHC i think with a little fabricating you can use the same RS Impulse turbo parts but need to modifiy it a little more...
The motors and trannies are interchangable (I.E. you can use a base storm tranny on an Impulse RS turbo motor, etc)....Also, all the motors will bolt up to any of the storm models (I.E. you can bolt a 1.8L DOHC in the same 1.6L SOHC storm...They have the exact same engine bay and If i am not mistaken they are all the same motor mounts)..I hope this helps...
~Justin
1990 Geo Storm GSI
And its my Civic Killer
Old 10-29-2002, 02:57 AM
Re: here is your answer evilpixie
~Justin
Nice explanition, my friend was thinking of doing the conversion or selling his slightly modified Storm, the one problem is he can't find any Turbo Impulses here!
AF MODELING FAQ
"Oh what a feeling.- Toyota
Old 11-13-2002, 08:49 PM
getnhi getnhi is offline
1.6 turbo engine
There were only 800 awd turbo impulses made, very hard to find anything.
Old 10-15-2003, 08:18 PM
koshernerd koshernerd is offline
Send a message via AIM to koshernerd Send a message via MSN to koshernerd
Cool turbocharging the 1.8 DOHC in the storm
there isn't any information out there on how to turbochare the 1.8 DOHC but you can!! the block size is EXACTLY the same as the 1.6 from Isuzu. now you may think that it's a whole week of work to change out parts, but just pull out your 1.8 DOHC and tear off everything from the block up and then also tear off everything from teh block up on the 1.6. actually you can still use your DOHC form teh 1.8 on the newly turbocharged engine. just bolt on the intake, and exust manifold from the 1.6 onto the 1.8 DOHC. you also will need the fuel system control module from the turbo'ed 1.6, it too will hookup just firn to the 1.8.and then drop it down into the storm. I haven't done this because I just haven't had the money to turbocharge my storm. but once I get enough money to do so, I will. I don't know exactly how much more boost the DOHC and the extra .2 leters will do with performence. but it shoudl make a good difference. theorticly you shoudl be able to feel the difference between the turbo 1.6 and the newly turbocharged 1.8L DOHC motor. if you have anyother questions about this change or need and more detailed explination, just email me, I would love to tell you all about it, and to hear how you like the change.
[email protected]
Old 10-27-2003, 11:26 PM
91rs's Avatar
91rs 91rs is offline
Just join the Isuzu Forum at www.kipanderson.net/forum. Everyone there is very helpful and there are alot of people there that have dropped the Isuzu 1.6 turbo engine into their Geo Storms, or do what I did and go buy a '91 Impulse RS Turbo AWD to build.
Old 11-18-2004, 08:33 PM
tlbaldaccini tlbaldaccini is offline
Send a message via Yahoo to tlbaldaccini
Question 1990 geo storm
1990 geo storm parts
help.....im looking for control arm swaybar bushings for base model 1990 geo storm and cant find no where..can someone tell me where i can find the parts needed for my car.....thanks..teresa [email protected]
Old 11-18-2004, 08:37 PM
Re: Impulse engine in a geo storm?
Old 11-18-2004, 08:49 PM
Re: Re: Impulse engine in a geo storm?
go to Stormowners.com or Isuzone.org don't mess with this forum, its deadsville
Old 11-27-2004, 02:32 PM
Lakeshow23 Lakeshow23 is offline
Re: Re: Re: Impulse engine in a geo storm?
Originally Posted by getnhi
go to Stormowners.com or Isuzone.net don't mess with this forum, its deadsville
It's not dead. I'm posting here!
Old 11-27-2004, 02:33 PM
You can buy them from the dealer, but they cost a pretty penny. Like $8-$12 per bushing.
Old 11-27-2004, 10:06 PM
Re: Re: Re: Re: Impulse engine in a geo storm?
Ok, you can stay here and talk to the walls, I'm leaving.
I have a whopping 14 posts, since Nov 02
Old 03-02-2005, 11:56 PM
Chip___ Chip___ is offline
I have a 1990 geo storm 1.6 dohc Can you run me through the steps of just swapping the turbo from the impulse to my car
Old 02-26-2006, 11:54 PM
Light Storms Light Storms is offline
an easier way to retro fit your engine bay is to mount the turbo in the boot where the spare would go im in the middle of this process now ive dreamed about all the details for years, i e self contained oil pump, cooler and filter
