Go Back   Automotive Forums .com Car Chat > Chevrolet > Camaro | Firebird > Camaro Discussions
Old 02-07-2006, 01:33 PM   #1
tg1hq
tg1hq's Avatar
Diagnostic test?
OK, what's the difference between the diagnostic test that a mechanic would perform on my vehicle, and what I can do with a paperclip inserted into the little box under my dash that blinks out code numbers??? (Other than the $60, a mechanic is going to charge me.)
Is the mechanic's test more specific? more accurate?
1989 Formula 350 5.7L
no cats
Dynomax cat-back exhaust
K&N air filter
Bosch MAF sensor
ACCEL distributor and wires
H&R Sport Springs
Falken Ziex tires on American Racing wheels
tg1hq is offline   Reply With Quote
Old 02-07-2006, 06:54 PM   #2
97cavalier
97cavalier's Avatar
Re: Diagnostic test?
i hear that the parer clip thing is not accurate, and the computer thing that the guy plugs in you car, tell codes right away. I think auto zone has a scaner that does it on pre 96 cars.
95 Z71 Silverado 4x4 ext. cab
Mods- Flowmaster Exhaust,Intake
97cavalier is offline   Reply With Quote
Old 02-07-2006, 06:55 PM   #3
LowETz
If you have the codes and can accurately interpert them.... you're golden.
On the other hand, he'll be using a Tech I or a Tech II(depending on whether you're OBD1 or OBD2), which will actually let him see where the problem is originating from. Sometimes a thrown code is identified as such, but is not the actual cause/problem but a reaction to the problem.... if that makes any sense.
Sometimes $60.00 is worth the headache of trouble shooting several different cause/effects w/in the OS(pcm).
What's the problem?
'00WS6/A3
Bone Stock 346
P292 B/FI
VENGEANCE RACING L92 416" Stroker
550rwhp/502rwtq NA
Track #'s coming-
F.A.S.T. 90mm | NW 90mm | TEA/TFS | TNT | ROSSLER | YANK | MOSER | QA1/HAL | BMR | WOLFE
"I spend my money on race parts and fuel...the rest I waste"
LowETz is offline   Reply With Quote
Old 02-07-2006, 07:37 PM   #4
altonjh
Is the diagnostic test done at a dealership any more extensive than using a scanner or reader at home? And, what is the difference between a scanner and a reader? I just bought an AutoXray EZRead 2000. Anyone else here have one and what do you think of it?
Thanks,
Alton
altonjh is offline   Reply With Quote
Old 02-07-2006, 11:19 PM   #5
blindeyed
eBay aDdict™
blindeyed's Avatar
Send a message via AIM to blindeyed
Since when does it cost $60 to have someone run your computer for codes? Advance Discount Auto Parts has always done that for free. Autozone probably does it too, but I never go there. But why did you pay around $200 (if it's new that is) for a code reader anyway? Just seems like a waste of money unless you're training to become a mechanic.
And the differences between a scanner and a reader, are just that. One scans the computer for timing issues, air/fuel ratio, etc. It's used to fix problems within the computer. Like say you are running a little lean because you just did a cam swap. Well, a scanner lets you go in and adjust the fuel so that your engine will be getting the right amount of fuel required to run properly. As for a reader.. it does just that.. it reads codes that the computer throws out. Just a basic way to diagnose small problems, like say your o2 sensor is bad.
Here's an example of OBDII scanner:
http://www.whitetigerimports.com/pro..._id=4609714283
And here's one of a OBDII code reader:
http://www.autobarn.net/canobd23110.html
- Jason
1995 Pontiac Firebird
User Guidelines | VB Codes Explained | AF Merchandise
"Each of us, is in the scheme of things, insignificant.
But millions of insignificant people, doing a tiny bit,
can add up to be a very significant force."
blindeyed is offline   Reply With Quote
Old 02-07-2006, 11:23 PM   #6
97cavalier
97cavalier's Avatar
do they make scanners for 92's?
Old 02-07-2006, 11:38 PM   #7
blindeyed
eBay aDdict™
blindeyed's Avatar
This link should help you out with that
http://www.aldlcable.com/
- Jason
Old 02-08-2006, 09:38 AM   #8
tg1hq
tg1hq's Avatar
The last time I went to AutoZone,they said they can't read the codes on such an old car (89). Maybe, I'll try Advanced Auto Parts or the Pep Boys.
My Formula is driving bad after an accident. Thought it was the MAF or exhaust problem, but I replaced those things already. I was thinking it's an ECM problem now.
no cats
K&N air filter
Bosch MAF sensor
H&R Sport Springs
Old 02-08-2006, 09:42 PM   #9
blindeyed
eBay aDdict™
blindeyed's Avatar
Yeah, they said the same thing to me. I told them I had OBD1, and the guy immediately said they couldn't run it for codes. So I then informed him that I had OBD1 with an OBD2 connector. He still insisted that he couldn't run it for codes.. I had to practically beg the guy to come out to my car and see for himself that he is able to run it for codes. He felt pretty stupid afterwards. This might not be the issue in your case, but it just reminded me of what happened to me. I guess I see why you spent the extra money to buy the code reader. Since there pretty much are no shops that can run your codes for you, then it's actually a pretty good thing to have around.
- Jason
Old 02-08-2006, 10:25 PM   #10
altonjh
I really hate to ask people to do something free for me. Even though I buy plenty of parts from them. Just the way I am. And, the closest parts stores are about 20 miles each way. Some cars or trucks just won't make it that far if they are really sick. And, I have 4 trucks of my own to maintain. So, I figured a reader should make my work a little easier.
Thanks,
Alton
Old 02-08-2006, 10:46 PM   #11
LowETz
Yeah AutoZone will scan the code for free on OBD2 pcms, but I thought he was refferring to a dealership..... they use a Tech1/Tech2 and this not only scans the code but allows him to look at other variables/paremeters in a effort to diagnose the problem over just scanning. Like I was saying, a thrown code for POxxx could be a result of another issue indirectly related to the POxxx.
Also, a cheap hand held scanner (ACTRON etc.) will not show hard codes, only soft codes which is where the Tech 2 is the ticket.
May can buddy up to a service manger at your local dealership and Tech 2 it for free.... been there done that
'00WS6/A3
Bone Stock 346
P292 B/FI
550rwhp/502rwtq NA
Track #'s coming-
Old 02-09-2006, 09:41 AM   #12
badbird8988
Send a message via AIM to badbird8988
if your going to buy a scanner i wouldn't go for anything specific like the tech II unless you only plan on owning gm's... if that's not your plan buy the snap on scanner... but the tech two is far more better if all you want is gm's... the paperclip thing is horrible unless you want me to post the code list tomorrow for you...
ALL THROTTLE NO BOTTLE
89' FIREBIRD
badbird8988 is offline   Reply With Quote
Old 02-09-2006, 03:59 PM   #13
tg1hq
tg1hq's Avatar
I called AutoZone and Advance and they wouldn't go back to 1989. I might try to swing by a GM dealership and try to get a free reading. Also, a GM specific scanner would not be a bad investment in my family. I have a Malibu, my Uncle's all Cadillac and Monte Carlo, and my Dad's got a Silverado! Plus there are those future GM's I'm planning to buy.
no cats
K&N air filter
Bosch MAF sensor
H&R Sport Springs
Old 02-10-2006, 10:13 AM   #14
badbird8988
yeah i'm not sure of the price on them but you would want to get a TECH II... i'm in an automotive high school right now and lemme tell you those things are amazing at what they can do... they will tell you anything and everything... cylinder misfire counts... you can turn things on manually through the scanner... they're just really cool to use but hard to get used too...
89' FIREBIRD
Old 02-10-2006, 11:12 AM   #15
tg1hq
tg1hq's Avatar
I'm an automotive novice, so is it going to be too complicated for me?
no cats
K&N air filter
Bosch MAF sensor
H&R Sport Springs
