Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 07-02-2006, 02:28 PM
Joe_Limon Joe_Limon is offline
Electric Turbo
Now before you laugh at my Idea hear me out...
Take a turbo, split it in two
Attatch a generator to one end and a motor to the other
In between the two put a capacitor/battery
I know it wouldn't be 100% efficient, but thats what the battery is for, during Idleing/Coasting/Braking/accelerating the turbo could be storing energy.
And when you need it, (accelerating) you can give the turbo 100% boost no waiting for engine revs, and no supercharger belt draining your overall horsepower
Now that I said what I have to say feel free to comment/criticise remember constructive criticism is the best kind
Old 07-02-2006, 05:35 PM
UncleBob UncleBob is offline
AF -Advisor
Re: Electric Turbo
1: good luck finding an electric motor that spins 150K RPM's. Even if you use a overly large turbo, you'd still need at least 60K RPM's. You'd have to gear it to the moon to achieve that, which will be very hard on everything.
2: the driving motor could also be used as the power recovery motor/generator
3: there is hardly any exhaust/intake flow on decel, and you would get nearly no power from it.
4: I don't think you realise, even if you could find a motor to fit the bill for this, how much power consumption it would take for a motor to turn over a turbo at the required output. You would only be able to use it for short spurts, because however many car batteries you have attached to the motor would drain very quickly.
There has been many smart people playing with electric forced induction over the years. The realistic examples that worked well, require around 1000 amps to run.
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
Old 07-03-2006, 12:14 AM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
Re: Electric Turbo
Yea, I agree, the current generated would most likely only be about 1/10, if not less, than the current required to spin the turbo.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
Old 07-03-2006, 02:26 AM
Re: Electric Turbo
Yes I know the battery would drain quickly...
But the time spent accelerating is minimal compared to the time spent coasting
And yes a transmition between the motor would probably be needed
(there would be energy lossed here, but mixed with 98% Effiecient motors it wouldn't be all lost http://www.tip.csiro.au/Machines/success/sc.html , a benefit to this motor is that it is flat and lightweight compared to traditional motors)
I work around mills that consistently operate at 10k plus rpm they are extremely reliable, yes I agree a 100x gear ratio is high, but it is doable. Besides the turbine itself would be more complicated and expensive to machine.
That and your either forgetting or just leaving out the fact that tremendous power can be captured from the aft end of the turbo charger. Dont forget that end also spins in the 100k rpm range, such power would most likely require a very large capacitor rather then a battery.
Also in the decelerating corner of things... you spend just as little time decelerating as you do accelerating
And who knows If you have the money why not invest in a regenerative braking system... that goes straight to the capacitor
Old 07-05-2006, 10:00 AM
astroracer's Avatar
astroracer astroracer is offline
Re: Electric Turbo
So, if you do get it to work, what does all of this complicated re-engineering gain you, performance wise, over a simple, lite-weight, exhaust operated turbocharger?
Mark
Old 07-05-2006, 11:48 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: Electric Turbo
Two words.....leaf blower!!
Old 07-06-2006, 04:08 PM
Re: Electric Turbo
What do you get? simple... a hybrid system that combines the best of the supercharger and turbo charger...
At low rpms you can crank the turbine. meaning High low end hp gains, and on the other end of the spectrum... since it still is a turbocharger you keep you high end hp gains. All together more powerful then either a super or turbo charger
Old 07-06-2006, 10:55 PM
AF -Advisor
Re: Electric Turbo
if you are coasting/deceling, the turbo isn't spinning at 100K RPM's. No throttle equals no exhaust flow equals turbo is doing nothing worth mentioning.
Old 07-07-2006, 11:47 AM
beef_bourito's Avatar
beef_bourito beef_bourito is offline
Re: Electric Turbo
not really, you're trying to get this to work on a very low power level. a simple small turbocharger will work just as well and won't be nearly as complicated. a small turbo will have no noticeable lag, and it won't have the drain on the engine like a supercharger. basicly you're trying to make a complicated answer for a simple problem. there's no way to get an electric turbocharger to work at any kind of significant power level. it would just be too heavy, too complicated and it wouldn't be nearly as reliable as the tried and true turbocharger. and just try to remember, if there are 2 correct answers to a problem, the simplest is usually the best, there's less to go wrong.
another thing to think about is that there will still be lag. the compressor will need to spool before it can deliver that extra air flow. so you'll still have to wait for the power to come on, it won't be quite like a supercharger. you might not need to wait for engine revs but you'll still have to wait.
Mr. T doesn't pity anyone who likes the Black Eyed Peas. He just kills them.
Mr. T speaks only when necessary. His main form of communication is folding his arms and slowly shaking his head. And regardless of the situation, he is always understood.
On the A-team, Face , Haniabal, and Murdoch were all masters of disguise. Mr T didn't have to wear a disguise. The bad guys didn't recognize him out of fear.
Old 07-07-2006, 06:26 PM
Re: Electric Turbo
Lets list some answers I might have
-Even though idling/decelerating/coasting may not be as prime as when the car is accelerating, you mustn't forget that at 2000rpm a 3.0 liter engine under no forced induction is still pumping out 6000 liters of exhaust vapours a minute, this time is substantially greater then the couple of seconds needed to counteract the turbo lag on a larger turbine
-Beef burito, I still don't see how you think a turbine spinning at 100k produces a very low power level... You might expect low numbers if your generating system is very ineffecient.
And on a different note, What if for the fore end of the "electric turbo charger" you hooked up a supercharger to your electric motor, that way you don't have to worry about the ineffeciency of a 100x transmition
As for simpler solutions. That is often not the case. I will provide you with three general examples to disprove that conservative saying
1. Cars in general. Go back 30 years and you will find a plethera of "simple vehicles" (by todays standards). Yet why do the complex cars of today last longer, and produce more hp (per liter of fuel)?
2. Computers, many older systems are very prone to crashing, yet today many more people have computers, and they crash alot less.
3. A screwdriver... A very simple invention, one you would think hard to improve on no?
That there is a multi bit screwdriver, no more getting up and looking for the right screwdriver, the one you need is always at your fingertips. Best of all you can replace the bits if they get worn out, or if you want different ones.
Old 07-07-2006, 11:15 PM
AF -Advisor
Re: Electric Turbo
The 6000 liters of exhaust volume is only true if there is no restriction in the intake. But you have a closed throttle plate, so there is an extremely large restriction in the intake.
An air pump isn't very effective when you plug up the intake.
Old 07-08-2006, 03:26 AM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: Electric Turbo
i have an idea....get a turbo and boost your car the old fashioned way like i did...it works and i'm not going to fart around w/ electric motors and other things. All you're doing is trying to build a supercharger w/o running it to the belt. It would be a good idea if you could get it to work, but i doubt it will work and be reliable...
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 07-10-2006, 08:14 PM
Re: Electric Turbo
Just to my car? pfft no... Its gonna be my university project and If I can make it work properly it might even be my gateway into the automotive world
Old 07-11-2006, 03:41 AM
AF -Advisor
Re: Electric Turbo
honestly, I think a mechanical version might be more productive....imagine a regular turbo with a procharger-like belt drive attached to it, but using a one way cog, or even an electric clutch. At "off boost" the cog/clutch is engaged and forcing the turbo to spin at whatever ratio you have it set up for. Then once the engine flow is high enough to spin the turbo at higher rates, the cog slips or you turn off the clutch.
No power loss, won't need 16 car batteries to make it work, never need to wait for batteries to charge up, and there's always an attractive simplicity to such mechanical "solutions"
But I want credit for it if it does pan out
Old 07-11-2006, 11:10 AM
Re: Electric Turbo
Hey that is a good idea, but you still would require alot of power, so Ill expand on your idea with this.
Use a solenoid to engage/disengage the turbo, when the turbo spins to fast for the motor disengage, when your coasting/decelerating/idleing and it slows down let it engage so as to charge a capacitor which would power the motor when you press the gas
also
Just realised that most cars have a 4 stroke engine
