Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 12-27-2005, 06:04 PM
tcfco2005 tcfco2005 is offline
Question No Oil Pressure
My car has like no oil pressure and i dont know why....At first it was low on oil but then i topped it off and my pressure was still at 0 at idle...when i punch it the gauge barely moves maybe to like 10 or 20 but thats it.The car runs fine sounds fine all exept for the no oil pressure....i dont know if this contributes to the problem although it hasnt happend before...but my car seams to eat 1 quart of oil about 1000 miles....i have not one leak under my car ever and i have no smoke...i cant find out why its doing this..any help will be nice.
thanks in advance...
o and its a 91rs 305tbi with 700r4 supposably only around 60000 miles on the engine...
1991 RS
305 T.B.I.
700-R4
Old 12-27-2005, 09:30 PM
Morley Morley is offline
Oil pressure sending unit... try changing that.
Old 12-27-2005, 09:52 PM
skibum1111 skibum1111 is offline
Send a message via AIM to skibum1111 Send a message via Yahoo to skibum1111
Does your car gradually loose oil, or is it all of a sudden its down a quart? If its gradual, its going to be a small leak, probably around the oil pan gasket, drain plug and pressure sending unit, as well as valve cover gaskets, the usual suspects. If its a sudden loss, the only way may be to tear the motor apart. I did a 3.3 in a buick that had the mystery sudden disappearance, ended up never finding the problem. Good luck.
Rusting out Honda Civic $900
Fart cannon muffler: $300
Assorted stickers advertising products you'll never own: $50
Having your @ss handed to you by a brick shaped suv: Priceless.
Yup, I own the suv.
Old 12-28-2005, 11:43 AM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: No Oil Pressure
Does the car make any noises such as knocking?
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 12-28-2005, 12:09 PM
Re: No Oil Pressure
no noise it runs perfect other than the missing oil and the gauge problem....and on the oil....im not sure if its all at once or over time ill start looking at it more...it cant be a leak cause i park in the same spot everyday i go home and there is not one drop on the driveway. And on the way home ill have someone drive behind me to see if im burning oil...but i never smell any...
1991 RS
305 T.B.I.
700-R4
Old 12-28-2005, 12:36 PM
FormulaLT1's Avatar
Fight the powwa!!!
Re: No Oil Pressure
Change the oil/filter and test the sending unit like Morley suggest. Probably your best bet. Hopefully its not the oil pump but hell thats better than a spun bearing but you most likely don't have that due to lack of other signs.
Old 12-28-2005, 03:40 PM
SG007's Avatar
SG007 SG007 is offline
Send a message via AIM to SG007
Re: No Oil Pressure
Yeah don't panic until you hear a big CRACK on acceleration....lots of fun.
-2000 LS1 Z28-1979 Berlinetta*sold*-1992 RS 25th Anniv. 350*sold*-
Old 02-21-2006, 02:11 AM
liderchris liderchris is offline
Re: No Oil Pressure
feel your oil filter if it is warm u have oil pressure -replace the sending unit if it is warm
Old 02-22-2006, 09:13 AM
bluedevilbowtie bluedevilbowtie is offline
Re: No Oil Pressure
Sending unit. I think mine was around $40.
Old 02-22-2006, 12:43 PM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
Re: No Oil Pressure
I'm agreeing with the sender or the gage itself. Did you trace the wire up from the sender? I've seen them fall apart from being baked under the hood over the years.
On the plus side, if you had no oil pressure, the engine would be making a very noticeable clatter from the valve train.
Bob
Old 02-22-2006, 12:44 PM
FormulaLT1's Avatar
Fight the powwa!!!
Re: No Oil Pressure
Guys please check the date of the last post before bringing back threads that are a few months old. Thanks
Closed Thread
