Go Back   Automotive Forums .com Car Chat > Dodge > Caravan | Voyager
Old 02-09-2006, 02:18 AM   #1
moparman58
Question 97 T&C Rear Window Washer
Was wondering if anyone has had a problem with the rear window washer? Mine doesn't seem to work at all, though the wiper works fine. I know the 1988s had a separate tank, but from the owner's manual and Haynes, looks like both the front and rear run off the same tank. Is there a separate pump? The front window washers work fine. Don't have to use it much here in AZ, but do like it to work when I need it. Thanks.
moparman58 is offline   Reply With Quote
Old 02-09-2006, 08:40 AM   #2
vipergg
Re: 97 T&C Rear Window Washer
They use the same tank but use a separate pump for the front and back . You could try pulling and reseating the connectors to each pump , don't know which one feeds the front or back but should be easy enough to figure if someone runs the front while you are looking at it .
vipergg is offline   Reply With Quote
Old 02-10-2006, 09:27 AM   #3
vipergg
You could also try going under the hood in the power dist center just above the battery and pull the IOD fuse for a couple minutes , this will sometimes fix stuff like this if the pump is still good , its all controlled by the bcm .
Old 02-14-2006, 02:18 AM   #4
moparman58
Thanks for the replies. Went out today to see what would happen, doggone thing worked fine. Would have been nice if it had last fall driving through some rain in CA. May have just dried up in the line here in the AZ heat and temporarily blocked it.
